1983 302; turbo or supercharger
An SC or turbo can be used on ANY year 302. Just not a STOCK 302. Forced induction requires that mods be made to an engine. Cast pistons won't live very long under boost. A special camshaft, as well as adjusted clearances inside the engine would be other mods needed for optimum power gains. Plenty of info on the net.
Theres more than a few guys running turbos on STOCK 5.0s, some making 400+hp.
I mean stock 5.0 with stock TB, stock intake, and stock heads.
Lots of boost on a stock 5.0 is not the best way to make power but, it can and has been done.
And heres a nice little 1177hp at 5800rpm carbed 302 that drove home from the dyno.
http://www.turbomustangs.com/forums/...threadid=37521
Originally Posted by stevef100s
Most of these are with a stock 5.0 GT block. These come stock with forged pistons.
400 hp isn't much to brag about. I can get that with a change of heads, rocker arms, and headers on a stock GT 5.0 engine.
[QUOTE]Originally Posted by stevef100s
Um, no you can't.[/QUOTE
If I say it it's true. http://www.carcraft.com/techarticles/116_0307_ford/
And yes, all 5.0 GT engines do have forged pistons.
I read that article and noticed something.....a set of 1.7RR's will help to increase the lift, but how in the world will they increase duration if the profile of the cam is not altered?
[QUOTE=stevef100s]
If you believe everything you read on the net, nevermind.
dillon.proctor173
03-06-2011 06:04 PM
kilbrethj
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-04-2007 07:10 PM
Pete B
01-20-2006 07:44 PM
