Garrett application on 4.6?
Old Aug 18, 2005 | 09:45 AM
White Noise's Avatar
White Noise
Hey I have found a deal on a Garrett turbo and would like to know if anyone could tell me if any Garrett turbos will work on a '99 F150 4.6. Also how I could determine which one this turbo is. I have already went to a site called turbocalculator.com and found many Garrett turbos but I am not real familiar with them and don't know which one this is. I will say that the turbo is the cheapest one I have ever heard about and it's never been used!
Old Aug 18, 2005 | 11:53 AM
Fredman's Avatar
Fredman
On my 4.6 I have a Master Power T-61, which is very similar to a Air Research or Garret T-61. Somewhere on the compressor there should be a small tag with a model number and serial number. If you have that model number you can determine what size turbo it is. On the exhaust housing the A/R might either be cast into it, or stamped into it. I have seen it both ways, and also not at all.
If all else fails, you will have to take it apart and measure everything to determine what it is.
Marlon
Old Aug 19, 2005 | 10:30 AM
White Noise
Thumbs up
ok thanks I will try to find a model number and A/R, otherwise I might just have to skip this deal. The reason I am so interested is because I definately want to charge my engine(no doubt about it); but this turbo is new and only $300! I would be sick if I didn't get it when it could fit!
Old Aug 25, 2005 | 12:49 AM
redneck_ford_guy's Avatar
redneck_ford_guy
Talking
dude garret sounds like a t3 which is used factory on merkur xr4ti's and you can make anything work on anything lol. i'm gonna put 2 garret t3's on my 91 f150 with a 302 5.0litre
Heiny_F350
Sep 13, 2012 07:14 AM
maevans
Sep 17, 2009 08:42 PM
Forddeiselman
Dec 29, 2005 07:32 PM
strangmk
Mar 20, 2004 10:59 PM
