Hi, I am new and just wanted to try and see if anyone could help me. I have an '00 Explorer. The brake lights quit at the same time except for the top middle one. We've tried changing the bulb and that didn't help. We checked the fuses and they all appear good. Any ideas? Any help would be so appreciated! Thanks, Kim
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Yours might be different, but the wiring diagram for a 97 shows the outer brake lamps are wired thru the lamps out module/LOM, but the center lamp isnt.
