Ignition switch revisited
Old Jul 6, 2005 | 10:11 AM
brider's Avatar
brider
OK, so I read the posts and searched the archives, and deduced that to remove the tumbler in my '66 switch, I need to turn to ACC, put a little pin in the little hole, and turn the key further counter-clockwise to remove.
But how do you re-install it?
I bought a new switch assembly, bezel, AND tumbler (cylinder) with keys, but I'll be damned if I can figure out how the cylinder INSTALLS in the switch with the two pieces in my hands. I've fumbled with it for well over an hour with no luck.
Looking at the cylinder, with the key in the OFF position, you can stick a pin thru the pinhole without really contacting anything behind it. But if you turn the key to the ACC position, the pinhole gets "blocked" by a feature of the cylinder; is there a spring or release or something in the face of this feature that the pin-thru-the-pinhole releases to allow something to happen?
I WOULD go out and stick a pin in the pinhole of my truck's cylinder to remove it to see how it all goes together, but I'm afraid I'll be hitchhiking home if I do. I OUGHT to be able to assemble the new switch on the bench first.
Help!
Old Jul 6, 2005 | 11:05 AM
bertha66's Avatar
bertha66
Turn the key to where it is "blocked" and use your pin to push in on the "feature", it is the release and the cylinder will turn more. The switch, turn it with a small screw driver to the acc position, the blade on the end of the cylinder should line up with the slot in the switch. Put cylinder with keys in into the switch and turn clock wise and it will lock into place.
Old Jul 6, 2005 | 11:12 AM
brider's Avatar
brider
Thanks, I'll give it a shot now!
Old Jul 8, 2005 | 10:47 PM
pootscratch89's Avatar
pootscratch89
Did you get it to work? They can be a little cantankerous!!
Old Jul 9, 2005 | 10:29 AM
brider's Avatar
brider
Yes, I did!
I actually had to turn the slot in the switch counter-clockwise BEYOND the ACC position, do the same to the cylinder (after using a paper clip in the hole), and it DID pop in. It would NOT go without turning both beyond ACC.
Next problem:
The existing switch WILL NOT come out of the dash, the bezel seems fused to the switch, and I've buggered the bezel up royally with vise grips trying to turn it.
I think I'll have to take a cutting wheel and cut the bezel away to get the switch out.
Another day!
Old Jul 9, 2005 | 01:10 PM
hiball3985's Avatar
hiball3985
reach behind the switch and push it forward towards the dash, its spring loaded, and that will release the bezel so you can turn it
Old Jul 9, 2005 | 07:18 PM
brider's Avatar
brider
Oh, HO... I've done that until my face was blue. I bought a new switch and cylinder, and with the help of the guys in this forum I figured out the whole assembly on my kitchen table. It just won't work in my truck, like I said, the bezel and switch body seem fused.
Old Jul 9, 2005 | 07:22 PM
hiball3985's Avatar
hiball3985
ok, let me finish my beer and I'll go look at mine, maybe I forgot something
Old Jul 9, 2005 | 07:37 PM
hiball3985's Avatar
hiball3985
ok, lets go back to square one, did you rmove the tumbler before you tried to remove the bezell
Old Jul 9, 2005 | 08:58 PM
mikecarson's Avatar
mikecarson
Just took the one out of my 64. I took the lock out of the switch first, then push and turn. Don't push too hard.
Old Jul 10, 2005 | 06:48 AM
jowilker's Avatar
jowilker
The bezel has a collar on it. There are notches in the dash sheetmetal that holds it straight. There is also two apposing slots in the collar that start straight and then turn 90º. The lock itself has a spring that fits between it and the back of the dash. It has two pins that fit into the slots on the bezel.
I have found some locks that did not want to give up the ghost and were comfy staying put. You must push (hard) from both directions to release catch.
First the lock tumbler has to be removed.
Second while holding the bezel the lock has to be pushed hard towards the bezel first releasing it and then turned counter closkwise to the straight part of the slot and then it should pop out in your hands.
Warning: It the tumbler is not removed first, the lock will not release.
John
Old Jul 10, 2005 | 08:04 AM
pootscratch89
I found that it is easier to remove the switch and bezel if you remove the dash panel; this way you have more room and can get you hands on the switch. Careful--those bezels are not cheap. I was so frustrated with my son's that I eventually broke the bezel and one of the teats off the ignition switch. I also found that turning the whole switch assy makes it a little easier to remove.
vernon
Kwikkordead
141
Apr 26, 2020 07:10 AM
Duckmang
Dec 20, 2014 03:15 PM
tractormanbill
Jul 19, 2014 10:33 PM
triskadek
May 24, 2014 12:52 PM
rickj000
Aug 7, 2004 05:50 PM
