2000 Explorer Horn & Cruise Won't Work
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Thats a pretty useless owners manual, if it does'nt even tell you which fuses are wired to which accessories.
The way you check for a bad fuse (normally) is to look in the owners manual & if everything thats wired to a particular fuse is NOT working then you check the fuse.
I dont have a wiring diagram for yours either, but my guess is that it has a clockspring under the steering wheel air bag, & it might be broken.
Dont mess with it if you dont have a manual that tells you how to disarm the airbag.
Have you checked the fuses under the hood?
Not for sure on the Explorers, but I did have a broken clockspring on a vehicle one time. My airbag light came on and I could hear a click when I would turn the wheel around. If you have these symptoms, go get it fixed right away. I was told that a broken clockspring wouldn't hurt anything for a couple of days until I could get into the shop, then when parking at the Home Depot my airbag went off. Costly lesson to learn. Oh yeah, the horn and cruise were not working at the same time.
Did you find out what caused it to go off?
biggdirty7.3
02-02-2017 10:13 PM
Mikey Cash
08-02-2013 08:40 PM
nebechanezer
04-26-2011 01:15 PM
