Lincoln Intech Conversion
Old Apr 18, 2005 | 04:00 PM
bigexpo's Avatar
bigexpo
Exclamation Lincoln Intech Conversion
hey i was just doin some research on my 5.4l and i saw that lincoln had a v8 in the navigator called "intech" which had 300 horses and 360ft.lb. is it possible to get lincoln "intech" parts from a crashed navi and put them on the ford triton engine to get these numbers or be the same as the intech?
Old Apr 18, 2005 | 04:57 PM
TDN's Avatar
TDN
The 4v Intech motor from the 99-04 Navigator is a completely different engine design than the 5.4L 2v Triton. The 05+ Nav uses the same 5.4L 3v Triton that is in the 05+ Expy. I don't think there are any parts from the Intech that you could put on your 5.4L.
Old Apr 18, 2005 | 09:16 PM
FTE Herman's Avatar
FTE Herman
The block configrations are the same. The heads, intake, exhaust, and timing chain cover are different (along with most of the accessory attachment points, accessories, and PCM). Without getting into too much detail, it is not worth swapping the parts out. You would be better served by improving existing components on your engine.
Old Apr 25, 2005 | 11:36 PM
Mud Doc's Avatar
Mud Doc
If you are interested in a complete engine swap, check out the Expedition Owners Group (EOG.com) there is a guy Brandon who has done this already.
Overall, as hkiefus said, it is not worth the trouble. Look at his sig--he knows what hes talking about.
Lincoln White
13
Oct 6, 2018 02:39 AM
olblue77
2004 - 2008 F150
Jun 2, 2016 09:29 PM
02KingExcursion
1997 - 2003 F150
Oct 22, 2013 08:28 PM
vjstangelo
May 13, 2007 11:03 PM
kwaskow
Mar 4, 2004 06:29 AM
