1978 - 1996 Big Bronco
331 or 347 in a Bronco?
Old Apr 11, 2005 | 03:05 PM
Cybertaz126's Avatar
Cybertaz126
Old Apr 11, 2005 | 07:03 PM
ALSAIR's Avatar
ALSAIR
I have heard that about the 347's burning oil and not very reliable. You are pushing that block to it's max. You have to cut the block for the longer stroke of the rods. They do make a 306 kit. If you are looking for realibilty and a daily driver, stay away from the 347. You know what they say, opinions are like A$$&%*(,s. Post your question in the engine forum or go to www.network54.com/Forum/119417
Al
Old Apr 11, 2005 | 07:12 PM
Cybertaz126
Old Apr 11, 2005 | 07:20 PM
ALSAIR's Avatar
ALSAIR
Are you in sanFORD Florida? Good luck no matter which way you decide to go. Keep us posted.
Al
Old Apr 12, 2005 | 11:07 AM
Kemicalburns's Avatar
Kemicalburns
go 331 for sure, you will need to either port/polish the heads or get some aftermarket aluminum heads like AFR 165 or 185's to really see the full potential of that motor. because the stock heads are a serious bottleneck .
Old Apr 12, 2005 | 12:15 PM
Cybertaz126
Old Apr 12, 2005 | 12:43 PM
Kemicalburns
with the cost of fuel i wouldnt go above 9.1 otherwise youll have to run premium and thats crazy expensive right now
Old Apr 12, 2005 | 06:37 PM
ALSAIR's Avatar
ALSAIR
I would'nt waste the money to have them shaved, however make sure the shop checks for warpage of the heads, which they might mill it down a little. Just check for piston to valve clearance during the build! Increasing stroke, and milling of the heads and probably roller rockers which will require longer pushrods, can possibly cause piston to valve clearance issues. Summitracing.com has some nice kits, I also here P.A.W. does too.
Al
Old Apr 12, 2005 | 08:11 PM
yomow's Avatar
yomow
My 347 in a 89 Bronco is 9.2 to 1, they all talk about it but never done it I did & w/ probe pistons you will not end up w/ any or the oil problems !!!!! As thay talk abought that I have done !!!!! My engine is a roller motor !! Comp. cams built it for what i was going to use it for, am using it for what i want to do !!!! man it has the power, stick with the 19 lb injecters! W /alum. heads you could go higher up to 10.5 to 1 , I do run high test !!!! Its a work bronco!!!!
Don
427mike
Apr 6, 2019 09:56 AM
351slug
Offroad & 4x4
Jul 12, 2008 09:52 PM
leithmc
Bronco II
Jun 10, 2004 01:25 AM
cm_aranda
May 28, 2004 12:32 AM
Goodold71
1966 - 1977 Early Broncos
Mar 6, 2003 12:30 AM
