How much pressure does a PS pump have?
1800 psi according to the Mustang mag I was reading today. It would probably work with a big enough cylinder to give the force multiplication you would need. But the speed probably wouldn't be what you want. PSI isn't the only factor in this app. Flow rate would be a big one here to get the cylinder to act fast enough. I have no clue what the flow rate of a ps pump is.
The electric pump for the flatbed on my '95 runs at 3000 psi. Can't find any flow rates in the book but it does have a 3/8's high pressure line to the lift cylinder.
If a 2000 PSI pump would only make it work a little slower you could probably get most of the other parts you need from Northern Hydraulics to make it work.
What type of truck is this going in? Standard or Auto? Have you looked into finding an old PTO rather than electric or PS pump?
Can these PS pumps handle hydraulic oil? Might be to hard on the pump running to thick of an oil in it? Not sure.
One last thing to research. Mounting points of the scissor lift will help determine....... How much you can lift and how high the body goes.......Research that before you just weld it on. There's 2 flatbeds and a dump body here I could take some measurements on for you if you got to that point. Good luck.
Check ebay. You can find 12 volt hydraulic pumps that are designed for this kind of pressure and volume all the time for $100-$200 which is probably about the same that you'll spend to make your PS pump work for it.
The larger the bore of the ram the less pressure you need but the more volume that will be required to move it. You need to get a hydraulic book to get the right mix which will provide enough force to dump the bed but won't require a HUGE amount of fluid. Large bores also move a lot slower.
