crossmember measurements
Old Feb 16, 2005 | 11:32 PM
bootie's Avatar
bootie
is someone able to take some measurements of a 42 -47 trans crossmember 4 me
Old Feb 23, 2005 | 11:01 PM
bootie's Avatar
bootie
anyone plsssse???
Old Feb 24, 2005 | 12:01 AM
Dodge41's Avatar
Dodge41
I got a couple of 42-47 half ton trucks. I cant do it tonight but maybe in about 24 hours I could give you an answer but first I need to know what it is you need to know about the crossmember?
Old Feb 24, 2005 | 12:10 AM
bootie's Avatar
bootie
basically i don't have a crossmember so figure i'll probably knock one up - i need the measurements and locations of the the hot rivets as well as the width and height of the crossmember, the location of the mastercyl and the drop from the top of the chassis to the mount
_____`````` _____
__O_ \_____/ ____
.......\______/
Old Feb 24, 2005 | 12:14 AM
Dodge41's Avatar
Dodge41
alright, its 1:12 am where I am at so give me a little while to get those measurments. Between the work, rain, and college ill try to work it in.
Old Feb 24, 2005 | 12:19 AM
bootie's Avatar
bootie
cheers thanx heaps
Old Feb 26, 2005 | 06:19 PM
Dodge41's Avatar
Dodge41
_____`````` _____
__O_ \_____/ ____
.......\______/
I had a chance to get some measurements off one of the old trucks I have before I ran out of time today. I got the width and some of the holes, wether or not anything mounts through those holes I dont know as my truck was stripped rather well before I got it. As for the rivet spots, drop of the mount in the center, and the hieght I will have to get later ( mid to late next week). All measurements are from the inside frame rails to the center of the holes using a tape measure as best I could. The pic is in my gallery, and one of the numbes is cut off by the "ford truck logo". Ill fix it once i get the last few measurments.
Old Feb 26, 2005 | 11:29 PM
bootie's Avatar
bootie
wicked thanks
Old Feb 27, 2005 | 09:23 PM
alittle40's Avatar
alittle40
Bootie,
You can also try here: http://www.wescottsauto.com/pdf2/FR-6.pdf
As noted the drawing goes to 1941, but frames to 1947 should be the same. How perfect are you trying to make this thing? Or are you just going to knock it up?
Old Feb 28, 2005 | 01:38 AM
bootie's Avatar
bootie
i'm kind of spending enough on my truck so she'll be neat and tidy what ever i make up - prob use tube to make the basic structure maybe something like this http://www.chassisengineeringinc.com...s2/ES-2151.jpg 42-47 trucks used a ladder frame system similar to the 48-52 f1 other than the body being the same they share little in common with the 41
Old Mar 1, 2005 | 01:46 AM
alittle40's Avatar
alittle40
Now that does look nice. Has that nice sleek look to it. Once made a x member like that for a Camaro that I owned, except that I pinched the ends before I welded them to a stiff angle iron. Where the trans mount goes at the bottom I slotted the tubing and inserted a tongue of flat iron inside and out the otherside of the tubing and welded both sides and touched up with a grinder to make it look nice. Put a couple of small fillets angled on the flat iron to keep her stiff, and that was her. I may have a picture somewhere around.
Old Mar 1, 2005 | 02:13 AM
bootie's Avatar
bootie
if it wasn't for the fact that it's left hand drive i'd prob just buy one
Old Mar 1, 2005 | 04:53 PM
alittle40's Avatar
alittle40
Bootie, Added some cross member pictures and ideas to my gallery that may help you out. Enjoy.
Old Mar 2, 2005 | 05:25 PM
uba40's Avatar
uba40
Smile 35 to 41 frames vs 42 to 47 frames
Hi Y'all,
For some reason, I thought we had already gone through this frame issue, and I thought I had done it!!! But my aging brain could have been wrong again!!
OK...........
The 1935 to 1940 passenger frames AND the 1935 to 1941 commercial (read 1/2 ton) frames are all nearly identical with the exception of the front crossmember spring mounting height and the little side body mounts.
The 1941 Passenger and 1942 commercial frames are ENTIRELY different.
There is no real interchangeability that I am aware of between the lot. If pressed, I have a factory parts book which we could refer back to, BUT, I am all but certain that I have got it together on the above.
So, I would have serious doubts that the crossmembers would be interchangeable between a 1940 passenger/commercial, and a 1942 commercial.
As always, This is My opinion.
If there is some serious doubt, we could always refer back to the factory parts book. Although we all know that it is not always accurate, it would be a pretty solid reference piece.
uba40
Old Mar 2, 2005 | 05:28 PM
uba40's Avatar
uba40
Talking oops!!
Booty,
My apologies, I just spotted your reply, after I missed it. before I posted!!!!!!!
Duh!!!
uba40
