Harmonic Balancer broke off cranshaft 98 Ford Explorer
Old Jan 22, 2005 | 09:55 PM
ssimp12626's Avatar
ssimp12626
Hello. I have a 1998 Ford Explorer with just over 100,000 miles. Is it normal for the Front Pulley to break off the crankshaft. Has anybody else experienced this? The Ford service center said that it was due to old age and metal failure and want over $2000 to repair it. THis is not the first time we've had the metal fail in this SUV, a couple of years ago the front axle fell off while driving. Thanks. SS
Old Jan 23, 2005 | 07:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 24, 2005 | 04:37 AM
95EXPLODER's Avatar
95EXPLODER
Find a used one and fix it your self. You can borrow the puller from Autozone for a deposit you get back. Save your self $1950 or more, as you can pick them up cheap.
Old Jan 24, 2005 | 09:32 AM
thelonerangerxlt's Avatar
thelonerangerxlt
SS, welcome to FTE! The crankshaft breaking seems to be common in Explorers. It always breaks behind the harmonic balancer, and usually happens between 40K and 120K miles. Usually after the warranty expires.
Several reasons have been suggested: A tolerance stack-up during manufacturing is one. Another is a flawed casting, poor metalurgy, etc. The one I like the best has to do with the replacement of the balancer during service for the timing chain. There's a tool to replace the balancer, and if it's not used, the balancer may not be installed fully on the crankshaft, causing eventual failure. This is just a theory, because no one seems to know for sure. Ford may know, but they're not talking.....
The fact is, no crankshaft should break during normal service. This is either a design flaw, or a mistake during timing chain repair causing the crank to fail, but Ford won't acknowlege it. Best of luck getting it repaired.
Old Oct 30, 2006 | 09:36 AM
casey3333's Avatar
casey3333
Unhappy
What did you guys do to fix this problem? My crankshaft is broke on the nose. I have called Ford and they seem to be very unhelpful.
Old Nov 1, 2006 | 12:13 PM
bdmcdonald's Avatar
bdmcdonald
If it is broken on the nose of the crank you will need a new or reconditioned crankshaft, rod and main bearings, gasket set, oil change, engine hoist.... In other words lots of time and some money. If your handy do it yourself or find a good mechanic and get it done.. Or sell it.
resq302
Aug 21, 2018 10:29 AM
axehandle
Jun 26, 2017 03:39 PM
HELMUT RONER
WTB - Parts & other
Jan 22, 2016 11:45 AM
SmittyVIP
Jan 21, 2013 11:22 PM
v8xploder
1978 - 1996 Big Bronco
Mar 15, 2010 08:40 PM
