Pull the front sheet metal off for engine change?
Old Jun 26, 2017 | 01:58 PM
axehandle's Avatar
axehandle
Left intact bolted to the front sheet metal. Is it as easy as it sounds? Sure makes the engine swap sound easier.
Old Jun 26, 2017 | 02:09 PM
itsnotavan's Avatar
itsnotavan
I too would like to know the once over for removing the "dog house". Ed on wheeler dealers made it look easy.
Old Jun 26, 2017 | 02:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by itsnotavan
... Ed on wheeler dealers made it look easy.
Then it must be true!
It involves removing the connections at the running boards to the fenders; at the frame to inner fenders (on 48-51's, at bottom of inner fenders); at the firewall/cowl; removing the radiator; removing the nuts from the two radiator saddle springs underneath; disconnecting all wiring for the front end and engine; disconnect heater hoses; remove the hood. Lift the whole works up over the front frame horns then forward.
Old Jun 26, 2017 | 02:29 PM
itsnotavan's Avatar
itsnotavan
so the radiator comes out first, not with the rest of the sheet metal.
Old Jun 26, 2017 | 02:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You can leave the radiator in the saddle, probably want to remove the shroud if you have one.
Old Jun 26, 2017 | 03:39 PM
F1 Mike's Avatar
F1 Mike
Did my engine removal by pulling the complete front clip. Put 2, 2x4's across the bed rails and flipped the clip upside down on them for storage. You need two strong bodies minimum, 3 is better.
Old51f3
Nov 21, 2018 09:40 PM
oxil
1947 and Older Ford Trucks
Oct 15, 2018 01:18 PM
wyazel1
Mar 1, 2015 12:36 PM
johnfin1
Oct 4, 2014 11:21 AM
DJ Rosa
Feb 21, 2003 01:47 PM
