F250 wont start if not pluged in
Old Jan 7, 2005 | 04:18 PM
Yzbat's Avatar
Yzbat
I have a 2001 f-250and it has been giving me alot of trouble with starting when it is not pluged and it is cold outside. It will start just fine when it is pluged in but when it is not pluged in I need to run it every 4 hours or it wont start and if it starts it will take about 15 min. of turning it over to get it started and I do wait for glow plugs to turn off I actually turn it off and on about 3 times and then try to start it. If I forget to plug it in in the mourning it will not start at all. Today I am changing the oil and puting a new fuel filter on today so I hope that it will help. I have 105,000 miles on it and I am thinking that it is also time to change the glow plugs and the relay. I just bought the truck and I dont know that much about them so If anyone could help me out I would appreciate it. Also I was wondering what type of oil and what weight would be best for this cold weather.
Old Jan 7, 2005 | 04:36 PM
wlihntr's Avatar
wlihntr
glow plug relay and or bad glow plugs could very well be the problem. if you are going to change the oil and want the best starting in the cold put in mobil 1 5-40 truck and suv (or mobil 1 delvac 5-40 if you can find it), you can get the "truck and suv" at walmart. it cost more but it helps alot
Old Jan 8, 2005 | 06:43 AM
MDB's Avatar
MDB
As stated, your glow plugs probably aren't working. The WTS light doens't have anything to do with whether they are actually working or not, just that they should be if all components are good.
Check your glow plug relay first. Check the voltage to ground on the side with the heavy wire, (this goes directly to the battery and will always be hot) and then when the WTS light is on, check the voltage on the oposite side (2 smaller wires). The voltages should be very close to the same. If they aren't, or you don't get any voltage you know that your relay is probably bad. Also, if the glow plugs are working you should see a noticeable dimming of the interior lights when the WTS light comes on. If your dome light doesn't dim you know that there is something wrong with your glow plug circuit.
You should also hear this relay click when the WTS light comes on. The OEM relay is app $60, but you can't get comparable relays for app $20 at other places. Do a search for glow plug relay.
Old Jan 8, 2005 | 08:11 AM
mr_fixit's Avatar
mr_fixit
Well the glow plug realy would be the easiest for sure and then the plugs themselves but are you seeing any smoke from the tail pipe when you are trying to start? Thats the key. Also I see that synthetic oil is the way to go and gets rid of looping when cold.
Old Jan 8, 2005 | 08:28 AM
Subsailor1127's Avatar
Subsailor1127
I had basicallly the same problem with my 2000. I took it in and had 3 bad glow plugs and the harness had some "issues" as well. Had all of that stuff repaired about a month ago and no problems at all since. Good luck, I know from experience that it is a pain.
Old Jan 8, 2005 | 01:16 PM
mr_fixit's Avatar
mr_fixit
What kind of issues did the harness have I am very interested in that my self.
Old Jan 9, 2005 | 02:33 PM
Yzbat's Avatar
Yzbat
Thanks for all of your help I did change the fuel filter and the oil and still the same thing. Also when I do try starting it when it is cold alot of smoke is coming out when I am trying to turn it over.
Old Jan 10, 2005 | 07:19 PM
mikexix's Avatar
mikexix
I just wanted to say thanks for posting the link to Carpentractor's page. I was having cold start problems, and upon testing, found that I had 4 bad glow plugs. The dealer wanted $600 in labor to change, so I decided to do it myself. The article was a godsend - I had the whole job done in about 4 hours. Total cost - $80 for the plugs!
This forum has been a great help - thanks all!
Old Jan 10, 2005 | 09:15 PM
FordPowerStroke's Avatar
FordPowerStroke
I just went thru the same thing with my 97, 135k miles. I changed out the glow plug relay without effect. Took it to the shop and had 3 bad glow plugs, wiring harness was fine. It starts now, not like a new truck, but it starts. Next winter I will put in thinner oil in the fall as well.
dougbrown
19
Nov 25, 2010 01:50 PM
jg96powerstroker
Nov 3, 2010 11:06 PM
dougbrown
15
Mar 30, 2010 08:48 PM
jonnymac
Jan 27, 2008 08:30 PM
Mookie
Dec 11, 2003 09:12 PM
