1994 F150 automatic shifts hard
Old Sep 18, 2004 | 08:03 PM
SmittyD's Avatar
SmittyD
1994 F150, 300 6 cylinder, automatic transmission almost "bang" shift on my way to work every morining. In the afternoon it is much better.
What can I do to fix this?
Thanks,
Smitty
Old Sep 18, 2004 | 11:23 PM
jamiesan's Avatar
jamiesan
Do you have a tach in your truck? Perhaps your idle is higher in the am(cold).
Old Sep 19, 2004 | 11:44 AM
SmittyD's Avatar
SmittyD
I don't have a tach....
I don't have a tach, but every time it shifts, it shifts very hard; even when shifting into overdrive. After it warms up it's okay.
Thanks for the reply,
Smitty
Old Sep 19, 2004 | 02:17 PM
Shadow Wolf's Avatar
Shadow Wolf
If the trans is the E4OD (Overdrive on/off switch on shifter) you need to replace the Manual Lever Position Sensor (aka Neutral Safety Switch). The part costs $36.99 from AutoZone and takes about 5 minutes to install. I just replaced this switch on my trans a few days ago and it now shifts like a brand new truck.
Old Sep 22, 2004 | 07:57 PM
SmittyD's Avatar
SmittyD
Thanks Shadow Wolf.
Thanks Shadow Wolf.
Where is it located at?
Old Sep 22, 2004 | 08:29 PM
Andyman8282's Avatar
Andyman8282
Well I guess it could be that... but I was thinkin more on the lines of something like a speed sensor.
Old Sep 22, 2004 | 08:50 PM
Egor's Avatar
Egor
That sensor is located right on the side of the transmission, where the linkage hooks up.
Old Sep 23, 2004 | 05:50 PM
SmittyD's Avatar
SmittyD
Thanks Guys
Thanks,
Smittyd
Old Sep 24, 2004 | 07:48 AM
Morky's Avatar
Morky
there is also a Service bulletin out
explaining that the ground for this switch can also be the problem
And it suggests that a splice be added to the ground wire,and running it to the negative side of the battery for a good ground.
(to solve this hard shifting.)
I got this info from a service garage, as mine was doing the same.
I have no idea where the splice goes, but the garage fixed it for me,
So I'm good to go.
Old Sep 24, 2004 | 05:46 PM
SmittyD's Avatar
SmittyD
Thanks Morky -- I am going to take my truck to the shop also and get it looked at.
Your reply is encouraging.
Smittyd
Jonathan Stone
General Automotive Discussion
Mar 8, 2022 05:52 PM
Randomx232
Feb 3, 2016 11:16 AM
ChancesDad
Apr 30, 2015 03:48 PM
cmb2481
Jan 24, 2012 08:15 AM
joewaldner
Jun 17, 2009 03:05 AM
