Overfilled tranny
Overfilled tranny
I have a AOD tranny and well it's over filled by a Qt. or so. would that hurt it? Would that give it more oil psi? the tranny is going. it sometimes bucks when i let off the gas and also slams down out of OD when passing a car also used to leak at the tail end and bogs down sometimes when going in to OD.
-Jack
-Jack
I ran one a quart over for about six months. You take a chance of causing a leaky seal. I don't think it will change the psi. Check and see if you have any vacuum lines to the trans that might be off or loose. I don't know what year you have. Good luck.
Boa1277
Nov 12, 2005 11:00 AM
bigbluebronco43
Dec 6, 2004 12:04 PM
