Bronco II Ford Bronco II
1988 Bronco II
Old Mar 17, 2004 | 11:08 AM
Todd Rogers's Avatar
Todd Rogers
Angry 1988 Bronco II
I have a 1988 Bronco II that starts and runs great. It has a rebuilt 2.9 V6 with @ 30K miles. The problem is when you start it and run it around the block and shut if off, it doesn't start, just turns over.....I changed the distributor coil and the throttle sensor yesterday.....runs a lot smoother....but when i shut it off....wait a few minutes and try to start it.......doesn't start....just turns over.............is it flooding? is there a fuel sensor??
please help
TR
Old Mar 17, 2004 | 12:01 PM
87 XLT's Avatar
87 XLT
Sounds like the ignition module might be going open when it gets hot. Try cooling it down with a wet rag & see if it will start.
Old Mar 17, 2004 | 12:31 PM
Ken00's Avatar
Ken00
Have you checked for spark when this happens, also pull a few plugs and see if they are soaked with gas. A common source for exccess gas is a leaking fuel pressure regulator, pull the vacuum line off after you have run it for a few mintues, gas in the line means its bad.
leonharu
Dec 1, 2015 07:08 PM
Viperfoxbat
Jun 8, 2015 11:14 AM
6t56
General Diesel Discussion
Apr 23, 2009 05:14 PM
yukonsly
Aug 12, 2006 12:07 PM
Longbed 68
Jan 20, 2004 06:48 PM
