Starting problem.
Old Jun 3, 2015 | 10:15 PM
Viperfoxbat's Avatar
Viperfoxbat
Starting problem.
I have a 1979 f100 I6 that has a problem .you know when you start a vehicle
And you try to start it too fast befor the starter has time to stop and it makes a grind nois. Well my truck some times does this right from the fist time cranking it over.is ther somthing wrong with my starter? Or is this somthing thes older trucks do?or is my starter going? Or is ther a deeper problem learking?
Old Jun 3, 2015 | 10:34 PM
Iseriad's Avatar
Iseriad
sounds like the teeth on the starter are damaged or it could be the flexplate or flywheel
Old Jun 8, 2015 | 09:16 AM
The Frenchtown Flyer's Avatar
Did you check to make sure the starter bolts are tight?
Old Jun 8, 2015 | 11:14 AM
seattle smitty's Avatar
seattle smitty
Once you get the starter checked out, yes, old vehicles very often have worn-out teeth on the flywheel or flexplate. But you don't have to buy those parts, because the teeth are part of a "ring gear" that is welded to the flywheel/flexplate and is separately replaceable at low cost for the ring gear, plus a small charge to have the old one removed and a new one installed, usually by a welder.
Powerstrokin7.3L
Oct 10, 2012 11:35 PM
YouNomie
Bronco II
Mar 25, 2010 09:31 PM
blueovalinvestments
Sep 18, 2003 11:59 AM
RedBilly
1983 - 2012 Ranger & B-Series
17
Feb 5, 2003 09:00 PM
thelakecrew
Bronco II
Jan 8, 2002 12:00 AM
