A Sliding Rear Window For A '46
Old Dec 19, 2003 | 06:23 PM
The Frenchtown Flyer's Avatar
I want a sliding rear window in my '46. the opening has been chopped 1.5". Has anybody built a sliding rear window for a '40 - '47 truck. I know Ford offered one as an option in the late '30's but I've never seen one for a '46. Getting the glass / lexan cut to size is no problem for me. What I would like to find out is the best way to fabricate the frame, fadricate the seals, and insure that it will be leakproof. Is there a company out there that builds these or can supply the materials to make it possible to build my own. I have access to benders, TIG welders, and presses.
Old Mar 8, 2004 | 09:20 PM
46 pickup's Avatar
46 pickup
you may want to think about a pop out window like on the sides of vans you get a nice clean look and they are a little harder to break in to.
Old Mar 8, 2004 | 09:28 PM
Yes, I thought about a tilt-out, but I am afraid that the hinges at the top and latching mechanism at the bottom will intrude too much into the head area of the cab. So that is why I prefer a slider.
Old Mar 9, 2004 | 12:38 PM
46fordtruck's Avatar
46fordtruck
I've never seen an actual kit to retrofit a sliding window into one of these trucks. They were offered as an option for the '46 models, but as you've seen, they were a rare option, very few had them. I have seen in some Mercury truck brochures that the window was standard for the Canadian Merc's, but most never had them. Does it have to be sliding, could it be a roll down kind of thing? I think Ford had roll down back windows in some of the '34 Fords. Might not be too hard to do, just need a regulator of some kind, or even electric power window motor, and fab a channel for the glass to slide in, and then a channel for water to drain out through. Just a thought.
Old Mar 9, 2004 | 02:16 PM
The rear window was framed in square tubing when the top was chopped 3" making it difficult at this point to cut it back up and make a roll up. I did consider it. I made a roll up side opera window for my '33 ****** coupe previously. I am going to make this rear window open - I just haven't hit on the right method yet. Thanks all for the suggestions.
vermillion95xl
Jan 15, 2014 07:09 AM
bart6180
Paint & Bodywork
Dec 1, 2006 11:47 AM
jwd1475
Oct 21, 2006 03:59 PM
honkydog
1997 - 2003 F150
Apr 1, 2005 11:10 AM
ungotz
2004 - 2008 F150
Jul 22, 2004 01:40 AM
