Sponsored by: Real Truck
Front Brake Rotor Replacement
Old Dec 13, 2003 | 10:37 PM
azguy2's Avatar
azguy2
I have a 1999 Super Duty 4 x 4. I want to replace the front rotors myself. I have done numerous cars and a Jeep TJ but never a 4 x 4 Superduty. Usually I loosen two bolts on the caliper, lift the caliper of the rotor, and tap the rotor off the spindle. What is the procedure for a Superduty 4 x 4? Do I mess with the hub? When I compress the disks do I need to be concerned about the AntiLock brakes.? Help
Old Dec 13, 2003 | 11:06 PM
valvestud's Avatar
valvestud
Your intended procedure is how I do my Excursion, which should be the same as the SD. No need to deal with the hubs since the rotors slip over em. Use a plate or block of wood and a large C-Clamp to compress the caliper pistons.
I would also be careful about what rotors you use as replacements. The factory units are notorious for warping. I replaced mine with the ART units, and they seem better than Ford's.
Next time, I'm going to use Performance Friction two piece units. ART uses Performance Friction pads when a customer orders them, and they're the onl;y pads I use.
Regards,
Joe
Old Dec 14, 2003 | 02:05 AM
Monsta's Avatar
Monsta
Sit. Stay.
You can also just use the old pad and a C-clamp. It may be easier to find...
Old Dec 14, 2003 | 06:13 AM
jschira's Avatar
jschira
The caliper bolts use Loc-Tite, so they are a PITA to break loose.
Old Dec 14, 2003 | 05:40 PM
Fordman4x4's Avatar
Fordman4x4
If the front rotors have never been off, they might give ya trouble...Spray some WD-40 around the hub. Spray behind the rotor too, let it sit for a while. Then get the baby sledge ready just in case.
Nelson
Old Dec 14, 2003 | 07:23 PM
azguy2's Avatar
azguy2
Thank you everbody for all the good information.
Old Dec 15, 2003 | 12:10 AM
Monsta's Avatar
Monsta
Sit. Stay.
Nelson
Speaking that...you can replace the word "rotor" with "wheel". Sometimes they can be a pain to get off, too!
Use some anti-sieze on the mating surface of the rotor and rim when reinstalling to prevent it in the future.
Old Dec 15, 2003 | 03:39 PM
Fordman4x4's Avatar
Fordman4x4
Good call Monsta...
I remember the first time i took my stock tires/wheel off, what a pain. It took some heavy swinging with a large rubber hammer to get them off. I made sure to put some anti-seize on the hub.
Nelson
hydrosmith
Nov 29, 2010 09:28 AM
dgpach
Jan 29, 2010 04:51 AM
electrified_cc
May 31, 2007 01:49 PM
goldsworthy
1997 - 2003 F150
Sep 9, 2006 09:13 AM
biederboat
Feb 12, 2003 08:13 PM
