Bleeding Brakes Problem
Old May 26, 2026 | 08:19 AM
john ulrich's Avatar
john ulrich
Trailering
I have a 2006 F150 4.6 Liter with 285000 miles on it. I just replaced the calipers and rotors and pads all the way around the truck. Before this the brake system was working fine except that the brakes were down to metal on a couple of them. I have bled the brakes four times now and the pedal still goes almost all the way to the floor. We kept constant check on master cylinder reservoir to make sure it didn't go empty. I am stumped at this point I have never had any problems bleeding brakes before.
Old May 26, 2026 | 09:46 AM
Don Ridley's Avatar
Don Ridley
Maybe a bad caliper? Probably remanufactured so anything is possible.
Old May 26, 2026 | 01:36 PM
Beechkid's Avatar
Beechkid
Sounds like the air is in the ABS module..... 1st use a OBDII program to activate the ECU brake bleed program... then I bet it will be ok. If you don't have a software program to do this, then take the truck on a dirt road and hit the brakes a few times to activate the ABS.
Old Yesterday | 04:45 AM
techrep's Avatar
techrep
did you pre-fill the new calipers ? check the brake lines, collapsed or pinched.
Old Yesterday | 08:00 AM
Don Ridley's Avatar
Don Ridley
Since you changed all calipers, there may be a lot of air in the system. If you did not cap the brake lines while the caliper was off, gravity can drain the system.
A pressure bleeder is a great tool. It can quickly bleed a system. It's also useful for brake fluid flushes. Motive makes a good one.
Old Yesterday | 11:12 AM
john ulrich
Trailering
Thanks Guys I will try these ideas and see if I can figure it out.
jleo
Apr 4, 2010 01:29 PM
StarTrash
Jan 15, 2008 06:13 PM
parrfict
1997 - 2003 F150
16
Nov 30, 2004 11:58 AM
steve_
Bronco II
May 21, 2002 07:14 AM
