I had my reputable local trans shop go through my trans and freshen up. I also had them install a transgo tugger kit, transgo line boost valve, and triple disc converter. It acts normally other than the shifts are hard going up, and even shifting down when flooring it and it kicks down. I have even made the holes smaller in the shift plate. Even smaller than the way the plate comes. I also have tuning backed off -50psi on all upshifts and downshifts. The way it is now it is acceptable, except when you force a downshift while lugging around and you get on it a bit. Having said that, it still should not need this much reduction. Not sure if the tugger kit along with boost valve is the culprit?
