Speedometer gear 72 F-250 questions.....
Old May 22, 2026 | 05:37 PM
white 66's Avatar
white 66
Speedometer is off by 10 or more(too slow). I want to install the correct gear but have questions. So pulled the gear and it says it is a 20T 2 D
I did a bit of research and based on my tires and gearing in the rear end, I think that I need an 18 tooth. What do you think? Are the 18s the same used in the 3 speeds etc. and will the 18 slip on and fit my application?
My differential is 3.73 Dana 70
The 8.75-16 tire translates to approximately 235/85R16 in modern metric sizing. This conversion is roughly 31.7 inches in total diameter and 9.2 inches in width, perfectly matching your 16-inch wheel
Old May 23, 2026 | 10:13 AM
manicmechanic007's Avatar
manicmechanic007
Right, I'd go with the 18 too, might end up with a 17 but 18 to start with and might be perfect
Old May 23, 2026 | 11:20 AM
white 66's Avatar
white 66
So if I order one, does it matter the specific application or will the 18 slip on to the end of my current cable going to the 4 speed?
Old May 23, 2026 | 12:01 PM
manicmechanic007
They should all go on your cable okay with the little clip and square hole for the cable
They do make LH and RH ones
Just match yours up by the picture or application
Old May 24, 2026 | 04:32 PM
GeneT's Avatar
GeneT
I just ordered an 18 tooth gear for my '72 F250 390 ATM 2WD off of Amazon. I had planned on getting it from Dennis Carpenter but they were out.
My gear is pretty chewed up and another forum member gave me the hint about reaching in to the hole where the gear came out and feeling the condition of the teeth in the tranny. Best I can tell, they seemed OK; and though the cable may need to be (should be) replaced it still works, so I will test the original cable with the new gear and see if the speedometer comes to life before ordering a new cable and a new retaining clip for the gear.
The Amazon purchase was about the only one I found that included the O-Ring for the seal at the transmission (and mine is really old). Anyway, it should arrive in the next week or so and I will verify the fit on what I believe to be an OEM cable.
For reference, below is what I ordered, I will update when I get it.
Amazon Amazon
Old May 31, 2026 | 05:14 PM
GeneT's Avatar
GeneT
The gear from Amazon arrived, it worked on the old cable, my speedometer is fixed but will still order a new cable.
Zachthemoo2
Oct 2, 2014 04:42 PM
Mr7.50headsup
Feb 20, 2014 11:22 PM
hivoltj
Jan 19, 2014 11:14 AM
Bluebronco85
1978 - 1996 Big Bronco
Oct 16, 2011 02:51 PM
ktbargun
1983 - 2012 Ranger & B-Series
Jul 24, 2006 04:56 PM
