need help with speedometer / gearing
Old Feb 20, 2014 | 06:14 PM
Mr7.50headsup's Avatar
Mr7.50headsup
1977 F-150 460 np435 35inch tires.
So im tackling why my speedometer doesn't read what MPH im going. I hooked my cordless to my Speedo cable and it works just fine. The gear itself (yellow) looks in fair condition but I don't know what it looks like new. So my next step is to get the gearing. No tag. So I count pinion rotation... 1.75 turns to one full tire rotation. Seems a bit low to me... Considering the truck runs out of gear (leaving in second) really quick and gets to going fairly fast with not a lot petal needed.... I was thinking it was more like 3.73 (which it is not)
So a long list of questions.
Is my Speedo gear bad?
What is my exact rear end gear?
If my Speedo gear is bad what gear do I need with 35 inch tall tires and whatever gear I have?
To make thing worse I was planning on gearing down the truck to make second gear last longer and a longer 4th. That is no longer an option cause that's way to thin a gear to support any real power.
Thanks in advance.
Old Feb 20, 2014 | 07:29 PM
Jklnhyd's Avatar
Jklnhyd
I have 35s on a '79, i run 15 mph faster than my Speedometer.
Old Feb 20, 2014 | 07:50 PM
bucks77ford's Avatar
bucks77ford
Your NP435 probably has an 8 tooth Drive Gear, so assuming your rear end is 3.73 and 35 inch tires, it calculates for a 17 tooth driven gear (white). There probably isn't anything wrong with the gears, just need a different tooth gear for the speedometer.
Old Feb 20, 2014 | 07:54 PM
turbohunter's Avatar
turbohunter
Just for fun.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old Feb 20, 2014 | 08:24 PM
Mr7.50headsup
Woah, slow down kids! My rear end gear is NOT 3.73, I was saying I thought it was much higher than what it is.
According to counting the pinion the gear ratio is 1.75, which isn't even produced. The lowest I can find was 2.70.
The Speedo doesn't work at all while driving. I have only got my truck not much faster than 60mph (im guessing) and it still doesn't budge.
So I can't figure out what my rear gear actually is.
I don't know where to start
Old Feb 20, 2014 | 09:16 PM
Mr7.50headsup
Just for the fun if it
Old Feb 20, 2014 | 09:34 PM
Jklnhyd's Avatar
Jklnhyd
So, your gauge doesnt register an mph, the cable is verified working.... So you are troubleshooting the gauge?
Old Feb 20, 2014 | 09:46 PM
bucks77ford
Have you pulled the inner cable out of the speedo cable housing to see if it's broke?
Old Feb 20, 2014 | 10:24 PM
Mr7.50headsup
As said ^^^ I hooked my cordless drill to the end of the speedometer cable and the gauge works. (maybe I didn't exactly make that clear, sorry)
Old Feb 20, 2014 | 11:22 PM
bucks77ford
Oh that's right. Now I'm guessing that it's the drive gear in the transmission.
Zachthemoo2
Oct 2, 2014 04:42 PM
btracy
Jan 8, 2013 05:46 PM
cbfomoco
Sep 23, 2008 03:10 PM
MikeGV
Sep 26, 2005 09:30 PM
brown 4x4
Dec 17, 2004 09:28 PM
