beware: Eastwood Rust Encapsulator Spray cans
After spending over 30 minutes cleaning and cajoling a can of Rust Encapsulator and getting nowhere, it finally sprung a leak at the opening and out came a black mess on my floor and over both hands while I wisked the bubbling can of liquid out the door and across my new concrete pad into a cardboard box. I spent the next 10 minutes trying to scrub the black off my fingers and fingernails. My skin is dried out and stained.
For comparison, I took out a used can of Rustoleum underbody spray that was on the shelf for the same amount of time and used similar to the Rust Encapsulator. After the required vigorous shaking it performed as it should.
Am I missing something. Am I to be resigned to use the whole can at one sitting? Just thought I'd share my experience. I'll likely switch to the Rustoleum product which is less expensive too.
They don't convert rust. They don't neutralize rust. They do not penetrate deeply. They do not stop rust that’s still active underneath. They simply stick to rusty surfaces better than normal primer, slow oxygen/moisture access and provide a temporary barrier. That’s it. If the rust underneath is still active (and it usually is), the coating eventually lifts.
Eastwood is especially susceptible to cans clogging. The material hardens internally because the solids content is high, the resin skims over quickly and it's not stable once partially used.
It's just not a structural solution at all. In reality it’s just a rust‑tolerant primer. It doesn’t stop active corrosion. It works only on well‑prepped light rust and is far less durable than blasting + epoxy.
Look at how many high-end body shops use it.
