Steering Column seal
Old Apr 16, 2026 | 08:39 PM
blue68f100's Avatar
blue68f100
I was going through my parts looking for items I need to media blast and clean up and run across this steering column seal.
I noticed that the lip was turned in which I thought was odd. Did Ford do this on purpose to improve the seal?
Seal turned in
Seal turned in
Steering column seal
My Ididit column is 2" od not the 2 1/4 as the original one. So turning this in would make a tighter seal.
Old Apr 17, 2026 | 07:58 AM
Coastal68's Avatar
Coastal68
My '68 F250 doesn't look that way. On mine the rubber seal is under the steel flange - might be with yours also. the seal extends as far as the flange and is secured with a hose type clamp.
Old Apr 17, 2026 | 12:13 PM
blue68f100's Avatar
blue68f100
Yes. That's the way mine was but the tube was turned inside to increase the pressure on the tube. 1st photo. Which I was though to be a little odd.
desperado_18_2000
May 14, 2019 10:53 AM
dmccorkle911
16
Jan 22, 2016 10:39 AM
RTaylor65
Jun 20, 2013 08:43 PM
67 429
Mar 2, 2011 11:44 AM
7278ford
Oct 25, 2009 10:29 AM
