Warped Hood
Old Mar 29, 2026 | 05:10 PM
pltnsgt06's Avatar
pltnsgt06
Warped Hood
Edit:
My hood is warped. I am replacing my fiberglass hood that fits with this metal one that does not. I measured them and the metal one is 3/4” wider. I put on a flip kit on today and it works great. There is still a little adjusting to do. But the drivers side roller will not line up and when I push it on the roller it still hits the fender.
thinking about running a adjustable style brace from the top hung hole to the center holes so o can pull it back in. If I do both sides separate I could dial in each side.
Anyone ever done this before?
Hood forced closed
Hood forced closed
Drivers side roller
Drivers side roller
Hits fender
Hits fender
Passenger side hits but might be fixed with adjustment
Old Mar 29, 2026 | 07:05 PM
lshort's Avatar
lshort
before I started tweaking the hood I would remove the flip kit and sit the hood in place and see how it fits.
I ended up adjusting the fenders to the hood with the hood just sitting there. I used some cardboard spacers to get the gap and elevation where I wanted it then put the flip kit on.
Old Mar 29, 2026 | 07:41 PM
Marten's Avatar
Marten
Interesting. My'53 hood did exactly the same thing in the same locations. For now I give the hood a small push to get it onto the rollers.
Old Mar 29, 2026 | 07:49 PM
pltnsgt06's Avatar
pltnsgt06
Tganks, got me to thinking since I changed hoods to measure the old one to this one, the new one is 3/4” wider
Old Mar 29, 2026 | 07:59 PM
lshort's Avatar
lshort
is it 3/4" wider in the front and back or just the back?
Old Mar 29, 2026 | 08:41 PM
pltnsgt06's Avatar
pltnsgt06
Just the back. The front fits great, needs to go over a bit but not much.
I was thinking of rods with a center adjustment mounted on the bolt’s in the middle running to the top hinge hole. Not sure if that will pull it enough, might have to mount to the bottom holes with the roller.
Old Mar 30, 2026 | 06:51 AM
Greg Rogers's Avatar
Greg Rogers
I'll bet that steel hood was bent outward when in storage?? When it was on a truck it shouldn't have gotten bent out-or widened. I wonder if you could buy some threaded rod to go across the rear on inside and adjust(tighten ) the nuts to pull in. Then see where it needs to be and bend hood back then remove rod?? I don't know if this would work but maybe you attach it to hood a ways forward so it would still pull in rear edges but clear firewall, etc. Have to remove air cleaner - hopefully not carb.. Good luck keep us informed how it goes.
Old Mar 30, 2026 | 07:15 AM
turnrjr's Avatar
turnrjr
Mine was warped also. He is the set-up I used.
Old Mar 30, 2026 | 07:50 AM
pltnsgt06's Avatar
pltnsgt06
I like that, thank you!
Old Mar 30, 2026 | 05:27 PM
Greg Rogers
That looks like a great job, Bob.
Old Mar 31, 2026 | 05:32 PM
pltnsgt06's Avatar
pltnsgt06
Man that worked great! Mine is not as fancy as yours but it does the job great!
THANKS A MILLIONS!
Will
riderboy1961
Jun 2, 2024 12:17 PM
riderboy1961
May 26, 2024 07:35 PM
thepitshop
24
Sep 22, 2016 07:56 PM
Connecticut Calvin
Jan 5, 2016 01:38 PM
mcali2
Aug 19, 2014 10:29 PM
