Fuel pump frustration
Old Mar 29, 2026 | 07:45 AM
turnrjr's Avatar
turnrjr
It’s dust off time after a long winter here. We had a couple warm sunny days 10 days ago and the salt had been washed off the roads so I took a short ride around the neighborhood. It was good for the 54 and me. Last fall I saw that the fuel pump looked a bit wet. It was oil not gasoline. I assumed the gasket between the block and pump was the cause. Yesterday I changed the motor oil in the 223 six. While under the truck I checked out the fuel pump and the leak doesn’t seem to be from the gasket area. After doing some research online apparently these cam driven pumps have a history of this. There are many reports of short lived failures. This was already the second new pump purchased. The first pump was installed during the engine rebuild early on in the restoration. It failed (leaked gas), before the restoration was done. I just ordered pump number three, a carter this time.
Old Mar 29, 2026 | 08:14 AM
lshort's Avatar
lshort
I had a similar experience with napa fuel pumps on a 390, 2 different pumps both failed after a few hundred miles by squirting engine oil out the vent hole.
after the second failure I switched to a edelbrock pump which was pricey but it has worked great for 2 years.
I think it is just that the quality of parts is not what it was.
Old Mar 29, 2026 | 03:39 PM
KULTULZ's Avatar
KULTULZ
If one has the original OEM pump, do not shiat can or core.
They can be rebuilt and upgraded.
New pumps are junk, plain and simple.
Old Mar 29, 2026 | 05:09 PM
8pack's Avatar
8pack
I had exactly the same thing happen on my 223! I went through 3 pumps including a stock pump. I have a thread on it somewhere but it just seemed so implausible that I would have multiple failures and I kept looking for other issues. Mine couldnt make it up a hill and would bog out as I approached 55 mph. Once I got a working pump on everything is good.
Old Mar 29, 2026 | 10:14 PM
mOROTBREATH's Avatar
mOROTBREATH
I have been through 3-4 fuel pumps in the last year, my last one leaked so much oil I had to apologize to anyone I visited. I recently switched to an electric pump but it has it's own teething issues as well--but no oil leaks.
I turned my failed mechanical pump in for a free warranty replacement and stashed it under the seat just in case.
Old Mar 30, 2026 | 05:36 AM
KULTULZ's Avatar
KULTULZ
IMO
Having to use methanol laced gasoline and the dismal quailty of replacement parts nowadays, it would be best to convert to an electric pump setup.
Old Mar 30, 2026 | 06:50 AM
turnrjr's Avatar
turnrjr
I don’t know if the first pump was the original but it’s long gone. Fortunately I’m able to get non ethanol gas in nearby New York state. It’s all this truck has used under my ownership. If this trend continues, I will switch to an electric pump.
Old Mar 30, 2026 | 08:18 AM
abe's Avatar
abe
Get your old pump rebuilt by someone like Cowboy John. I had an original style pump with glass bowl I sent to him. He sent it back looking great with ethanol proof rubber. Google his name and you'll find his contact info.
Old Mar 30, 2026 | 09:07 AM
lshort's Avatar
lshort
I have never had good luck with electric pumps mounted outside the fuel tank.
If i were going to use a electric I would use a regulator with a return line because with a deadhead regulator the pump is going to be working under full load all the time and get hot and I would carry a spare.
Old Mar 30, 2026 | 04:19 PM
turnrjr's Avatar
turnrjr
Thanks Ishort. If it comes to that I will do the research to try getting it right the first time. My tank has a bung for a return line. Unused right now.
Old Apr 3, 2026 | 11:15 PM
8pack's Avatar
8pack
I used a US Motor works pump not a Carter pump. So far so good. I had 2 Carter pumps fail.
https://www.ford-trucks.com/forums/1...mp-failed.html
Old Apr 4, 2026 | 08:50 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Wow, lots of new fuel pump failures mentioned here and dismal new part quality. Unrelated to the Ford truck pumps, I am now on new electric pump #4 on an old Datsun I have. OEM pumps are non-existent for those so the only option is to find electric replacements. And they are terrible. They will either fail right out of the box or within 2 hours of usage. I use new filters between the tank and pump and have a clean tank and a pressure gauge inline. Part quality is horrifying. I have bought higher priced pumps each time hoping for an improvement. This fourth pump I'm on is already groaning which means it will fail soon, and it cost more than double the cost of the first one. I have little confidence in aftermarket parts anymore. The good news is that I can now change a Datsun fuel pump almost one-handed and soon will be able to do it with the engine running and not leak a drop.
I second Abe's suggestion to use Cowboy John in Florida to rebuild Ford carbs and pumps. He is great.
Old Apr 4, 2026 | 02:32 PM
1952henry's Avatar
1952henry
If you would choose to rebuild it yourself, either with a cowboy John kit or Now and Then Automotive kit, open it up and check how valves are held in place. Ford pumps have a little metal spider that holds valves in place with a screw. Aftermarket, at least some, have valves pressed in. The usual kits have the valves for use with the spider. They aren’t that complicated.
mOROTBREATH
Sep 11, 2025 06:43 AM
nothercrash
Dec 31, 2024 05:13 PM
The mad scientist
Mar 3, 2022 11:11 AM
benbuilder
Oct 16, 2012 05:09 AM
bigbadwolfe
Apr 1, 2008 08:27 PM
