Fuel pump
Old Oct 16, 2012 | 04:41 AM
benbuilder's Avatar
benbuilder
Fuel pump
I have a 75 f100 with a 1980 ford 302 motor. I have a small oil leak at the fuel pump. Is the leak as simple as a gasket replacement or should I replace the entire pump?
Old Oct 16, 2012 | 04:59 AM
garthneddy's Avatar
garthneddy
I would replace the gasket unless the pump is bad.
Old Oct 16, 2012 | 05:04 AM
benbuilder's Avatar
benbuilder
fuel pump
And it is obviously just the gasket on the block, otherwise it would be gas coming out and not oil, correct?
Old Oct 16, 2012 | 05:09 AM
garthneddy's Avatar
garthneddy
Every mechanical fuel pump I have seen that went bad leaks gasoline into the motor oil, not motor oil out of the fuel pump.
64rednwhite
Jul 7, 2017 10:14 AM
53rat
Jun 18, 2009 10:28 AM
jsutton
Mar 24, 2008 11:33 PM
Jaaaaaaackman
Sep 16, 2006 11:09 PM
woppini
Jan 14, 2002 03:57 PM
