What are you running for LED reversing bulbs?
Old Feb 20, 2026 | 12:19 AM
AAA_in_OR's Avatar
AAA_in_OR
The tech folder is rather outdated on this, so what are you running for aftermarket LED reversing bulbs? They're the last things that's not running LED's on my truck, and greatly need upgrading, cause I can't see **** reversing as it's so dark at night where I live.
Old Feb 20, 2026 | 06:06 AM
Freedom-over-safety's Avatar
Freedom-over-safety
Auxbeam LEDs from amazon. Works great, been in there since 2019.
Old Feb 20, 2026 | 08:45 AM
65Bronc's Avatar
65Bronc
4wd Low
When switching from standard to LED bulbs, are there any wiring or other changes required? Do they have any tendency to overheat the enclosures?
Matt
Old Feb 20, 2026 | 11:27 AM
Don Ridley's Avatar
Don Ridley
Matt
LED will not overheat the enclosure. BUT the opposite is a concern....the enclosure can overheat the LED. Heat kills LEDs . If you install high intensity LEDs continuously in an enclosure, they will die prematurely. You can get away with installing high intensity LEDs backup bulbs because they will only be on for short periods.
Old Feb 20, 2026 | 01:05 PM
65Bronc's Avatar
65Bronc
4wd Low
Gotcha, thanks.
Matt
Old Feb 20, 2026 | 02:48 PM
AAA_in_OR's Avatar
AAA_in_OR
Don't suppose you have a part number or a link for the Auxbeabs?
Anyone got anything more recently?
Old Feb 20, 2026 | 05:42 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
I used these from Amazon the work great and really light up the night Ultra-bright LED bulbs for upgrading tail, brake, backup, and turn signal lights. Easy installation and long-lasting performance. It's a popular product! https://a.co/d/07FxYn9l
Remember if you switch to LED brake or turn signal lights you have to change to an LED flasher which is located behind the radio. Just switching to LED reverse lights does not require any modifications. You will not be sorry for upgrading.
Old Feb 23, 2026 | 06:11 AM
Freedom-over-safety
Auxbeam 3156 T25 P27W LED Bulbs, 6500K White, Super Bright LED Turn Signal Backup Direction Blinker Lights for Cars Trucks Motorcycles, 3030-SMD 12V, May Need Resistors https://a.co/d/07FNm74H
Waco-kid
Jun 2, 2021 11:21 PM
charles adams
Feb 15, 2019 08:45 PM
Jesser02EX
Jun 12, 2013 10:02 PM
SNIPER 222
Jul 28, 2003 08:12 AM
XXXcursion
Jun 19, 2003 08:50 PM
