Struggles to go in overdrive Plz Help
Old Feb 7, 2026 | 07:38 PM
CaseII's Avatar
CaseII
3rd Gear
Question Struggles to go in overdrive Plz Help
I have a 2003 Ford Ranger 3.0 v6 5r44e Trans and its RWD i have replaced almost everything causing a P0741 code
I have Replaced OD,INT,REV/1ST bands and all clutches torque converter and TCC solenoid i looked over the Valve body and put gaskets and cleaned the whole thing i put the check *****/springs/little hole thing as well
it drives good until highway or flat surface pushing past 40 only flashes OD light no check engine light
Could it be my pcm?? i wiggled it a little then i drove it then it started working till it got bumpy on the highway and stopped working after a bit maybe just coincidence that it happened? i also checked for pinched wires near the trans didnt rlly see anything bad didnt check near the exhaust or pcm is there anything else i should try or do????
Old Feb 8, 2026 | 09:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
P0741 doesn't indicate a problem with overdrive. It shows a problem with the torque converter lockup clutch, meaning the computer detects excessive slippage because the clutch isn't locking at highway speeds. Common causes include low fluid, a faulty TCC solenoid, or internal transmission damage (e.g., worn seals/valves).
Did you replace the seals on the input shaft? You said you looked at the valve body, how about the pump body, where the TCC valve is located?
Old Feb 8, 2026 | 09:21 AM
CaseII's Avatar
CaseII
3rd Gear
When i had it apart we noticed everything was new clutches where exactly the same to the new ones we measured as well no difference when i looked at the pump it had new gaskets i never took it apart since it had new gaskets and etc and from what i remember i did replace the input shaft seals and i cleaned that valvebody rlly good it looked new after i was done with it lol
350Fitter
May 3, 2018 08:28 PM
Birney
1997 - 2003 F150
Mar 17, 2017 10:17 AM
DAN-D-DIESEL97
Oct 12, 2015 04:06 PM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
rachase70
1997 - 2003 F150
13
Aug 31, 2007 09:12 AM
