Help with oil-pressure sender voltage
My 66 F100 (I6 240) does not have an oil-pressure sender currently. I have the stock gauge cluster and I'm looking to get the oil-pressure light working again. The fuel sender, water temp sensor, and gauge lights all work so I have some confidence that the voltage regulator is working. I can trace a white-red stripe wire from the idiot light in the gauge thru the bulkhead to the engine bay (wire was just flopping around) but when I measure the voltage on it, I get 12V. I had thought the voltage regulator would have cut that to 5V.
Should I be seeing 5V or is this 12V correct? I understand that the white/red wire isn't under load when I measure but I would have thought the load from the other functioning sender/lights would have served that purpose.
Before I just ground out that wire to see if the light comes on, I figured I should check here. And, if that 12V is sign for concern, any suggestions for next steps? Do I have a bad IVR?
Also the oil-pressure sender port on the motor has a plug threaded into it which will need to come out. If anyone has had to remove a similar plug and has experience to share, I'm all ears.
Thanks in advance,
Jeremy
White/red = oil‑pressure warning lamp feed. It is not fed by the IVR. It is fed by full system voltage (battery/ignition). The sender on the block is a simple ground‑switch, not a variable‑resistance sender. The lamp circuit goes from Ignition 12 V to bulb → white/red wire to sender → ground. Meaning with the sender unplugged, the white/red wire will ALWAYS show 12 V. That's your potential voltage or open-circuit potential. With the sender grounded, the lamp lights and the wire voltage drops to 0 V. So, your 12 V reading is exactly correct. You should be safe to ground the wire, and the lamp should light up.
