Most manuals and YouTube videos say to use RTV silicone for sealing the differential covers, but has anyone tried using/making gaskets instead?
Is there an advantage to using sealant over a gasket or the other way around?
I used sealant when I did my rear diff a few years ago...but I always have a problem lining up the holes, while lying on my back and supporting the cover....a gasket would be so much nicer.
Lube locker makes reusable gaskets, I got then for my front and rear differentials and transmission pan and they work great. I believe they were around $30 apiece
I really like the lube locker. Here's a thread that goes into all kinds of things, but it seems the lube locker is best called for if you don't have a drain plug on the diff cover. If you have a drain plug, then it doesn't really seem to matter one way or the other:
So I got this done yesterday...fluid was BLACK...like coal.
According to my records, the last time I did this was just over 40,000 miles ago...yet the manual recommends it to be done every 105,000 and there is no mention of shorter intervals for towing.
I can't imagine what condition this stuff would have been in had I waited another 65,000 miles.
I used the Permatex stuff as show above, but if I were to manufacture my own gasket for this...should I use paper, fiber or cork?
I would stick with the Permatex, or go with LubeLocker.
Paper, fiber, or cork will weep and you will lose fluid over time.
How much fluid, and does it matter? I have no idea, but, with the Permatex or LubeLocker, If I see ANY seepage I know I need to stop and examine the fluid level ASAP.
If you don't mind checking your fluid levels every so often, then I would go with whatever is easiest for you to get.
I've seen people on YT make gaskets from Coke/Pepsi carton "cardboard" and it works (albeit with the seepage I mentioned above).
In my younger days, I made gaskets from "Mr. Gasket" cork for valve covers, diff covers, etc. They ALL weeped. Didn't matter what I did, they always seeped fluids. So when I got older and had some more cash on hand, I went with better gaskets. Less work and I like less repeat work for the same job.
Glove up, and smear permatex on a paper gasket. Has never failed me.
Reusable rubber gaskets are great when they work. But theyre easier, not better.
Captured o-ring would be best. But ive never seen one on a diff cover.
