1978 - 1996 Big Bronco
Top bolts stripped- rethreaded to 5/16-24
Old Jan 7, 2026 | 11:07 AM
351Cleveland C4's Avatar
351Cleveland C4
A few of The topper bolts on my 86 were not in great shape, and finally stripped out. In my opinion, the M6-1.00 weren't up to the task to begin with, but they did last almost 40 years.
So anyway, the two outside bolts on top, and the two at the extreme rear are actually encased nuts in the body, rather than the speed nut style clips. I drilled them and tapped for 5/16-24 bolts, and there's a great improvement in holding power. Not that they need to be torqued down much...
Anybody else with this problem may find this helpful.
Old Jan 8, 2026 | 04:01 AM
manicmechanic007's Avatar
manicmechanic007
Topper bolts?
You talking about the upper intake / plenum?
Good job of fixing it without having to replace the intake manifold
Old Jan 9, 2026 | 11:53 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Topper bolts?
This is the FSB section so I’m fairly certain he is talking about the fiberglass cap.
Old Jan 10, 2026 | 10:20 AM
manicmechanic007
Okay
Right, those bolts sucked, I broke a few off and replaced several sets
So did the gasket / weatherstrip
Used to see the tops bolted down with the weatherstrip twisted or out of position
We used to tell people to either take the top off each year and lube the bolts and the weatherstrip / gasket or never take it off
+1 for re tapping them (not easy)
I still have a few of those bolts kicking around
We used to replace them often, about half were cross threaded from the factory it seemed
Mini Vent Lube (Motorcraft XL10) is what to put on the weatherstrip
richjm
Mar 15, 2024 11:09 AM
Restoman2
Mar 18, 2011 12:40 PM
gbroehl1
Connecticut Chapter
Oct 15, 2009 05:27 PM
lockups
Jul 1, 2004 10:42 AM
