Modular V10 (6.8l)
Transmission strangeness last 2 times towing, Mike's 5 Star at the root?
Old Nov 24, 2025 | 02:27 PM
makemeknowit's Avatar
makemeknowit
Did a turn and burn, Memphis to Bristol and back. Coming thru Nashville, loaded, the truck will barely continue to move regardless of throttle. Pull off, check fluid, a little low, add maybe 1/3 quart. We are able to continue. This past weekend. Memphis to Little Rock to Enid MS. Loaded from LR to Enid. Unload in Enid, forgot to switch back to 87 Performance after getting the car off the trailer. I dont put the 87 tow tune in when pulling the empty trailer (16' dove). Truck starts doing the exact same thing, barely wants to move throttle be damned. Trans temp never showed high on either of these times. First chance to stop was 5-6 miles at a gas station. This time fluid was not low at all. Switched to 87 Performance tune, issue went away. Is whatever the tow tune does an indication my trans is possibly on its way out. No other issues trans wise. 236K on trans, I've put 85K of those on it. Had front seal replace back in '17 and put in a more towing friendly tc. Just weird how this past weekend the issue went away with the tune swap.
Old Nov 24, 2025 | 03:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When it doesn't want to move, what happens? Does the RPM go up, but the truck doesn't move? Does the RPM stay low and won't rise?
Old Nov 24, 2025 | 03:50 PM
makemeknowit
It doesn't slip, just doesnt want to move, like it's being held back
Old Nov 24, 2025 | 03:56 PM
Mark Kovalsky
That is almost certainly an engine problem, not a transmission problem.
mojavearcher
Aug 25, 2021 10:49 AM
SoCalAngler
Nov 10, 2018 08:08 AM
hotrodfeguy
Oct 27, 2018 12:02 AM
makemeknowit
Modular V10 (6.8l)
17
Nov 25, 2017 11:34 AM
blkbest
Jun 3, 2010 08:46 AM
