Help to identify these Cam shafts?
Both the Left and Right Cam shafts are worn and causing big misfire issues. The car has been out of action for a few months now.
The issue is (becaue it's part of a batch due to go to the middle east, but didn't) the car does not "exist" on the Ford systems so the VIN (1FMJU1H5XFEF03802) does not help. I bought a 2014 pair of cam shafts from Rock Auto and sadly they do not fit. (Since there is not 2015 V8 model in the US, usually 2014 parts fit fine).
All I have left is the numbers printed on the old cam shafts which may make it possible to find a matching pair? (9F-9L3E-6251-CA and 590147648)
If anyone can help me identify the matching cam shafts I'll buy them again and work out how to ship them here to the UK.
Thanks in advance for any help.
-Dan F
I used https://www.rockauto.com/en/catalog/...,camshaft,5260 to find the 2014 cam shafts and as you will see, the numbers you quote above don't appear anywhere in the listing/INFO as far as I can see. (They also don't match what is in my photo of the original camshaft we took out)
This is what it says about the 2 i ordered:
https://www.rockauto.com/en/moreinfo...&pt=5260&jsn=1
https://www.rockauto.com/en/moreinfo...&pt=5260&jsn=2
If I search rock auto for 9L3Z-6250-C and D I am getting "not found" messages so it's a bit confusing.
Ford Europe won't talk to me about imported Fords that are not available here (I've had them almost 30 years and they know nada!)
It's getting dark so I'll pop back to the garage and get some more info / photos.
thanks again
Rgds
Mike
thanks again
Rgds
Mike
More info off the engine itself could help us verify whether the U.S. spec cams could work, we can't comment on the aftermarket stuff.
-Steve
thanks
Mike
THis is the best I could get - the lower sticker was flaking off as we moved it so we can't see the lowest numbers properly
This is the best we could get of the bottom sticker
The two on the left are the new ones but the notches in the ends don't match the originals)
This is the original camshaft that worked for 10 years and we're trying to replace (says 9F-9L3E-6251-CA on it)
Better pic of the notches that do not match the original cam shaft
RF-9L3E-6251-CA <- the one I have and you do too
RF-9L3E-5C255-C <- the other one I cannot check as it's in the engine still so just wanted to check the 5C255 bit was right as it's an extra character
Thanks
Mike
Thanks
Mike
