Accessory Delay relay never grounding out. possible gem module problem
Old Jul 28, 2025 | 05:53 AM
Steve0373's Avatar
Steve0373
Trailering
Angry Accessory Delay relay never grounding out. possible gem module problem
I have a 2003 F350 Superduty I recently removed an aftermarket Avital remote start/alarm system from. With this system removed, I no longer have power to the stereo or to powered windows. Everything else appears to work fine. It turned out relay 306 had been completely removed from the fuse panel, I replaced it, and after some probing, it is evident that relay pin 85 is never being grounding out. If I jump a ground to pin 85, the stereo comes on and the windows work. I checked the pins in the central junction box and they all look good, clean and tight. Does anybody have ideas of what to check next?
Old Jul 28, 2025 | 07:01 AM
Pikachu's Avatar
Pikachu
I've no idea how that remote start wired in and it could definitely have something to do with the problem, but another cause of those symptoms can be a bad relay in the instrument cluster.
Old Jul 28, 2025 | 07:17 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Check a schematic with a beginning focus on pin 85 and what happens before it.
Old Jul 28, 2025 | 07:54 AM
akcooper9's Avatar
akcooper9
Easy fix, check this thread out:
https://www.ford-trucks.com/forums/1...auge-poll.html
Old Jul 28, 2025 | 08:43 AM
Steve0373's Avatar
Steve0373
Trailering
Thank you, I'll check that.
Old Jul 28, 2025 | 10:03 AM
Steve0373's Avatar
Steve0373
Trailering
The contacts all look great, no cracks, very clean.
https://www.ford-trucks.com/forums/1...auge-poll.html[/QUOTE]
Old Jul 28, 2025 | 10:33 AM
Eman85's Avatar
Eman85
Use a magnifying glass and look for any cracks in the solder.
Old Aug 15, 2025 | 02:28 PM
Steve0373's Avatar
Steve0373
Trailering
Accessory delay relay problem Solved!
Here’s how I finally fixed the problem!Since I had the instrument cluster out already, I went ahead and re-soldered those joints and put everything back together… it still didn’t work.
I traced down the wire that grounds out pin 85. It is the light blue wire coming from the large multi pin that attaches to the back of the relay box and runs all the way up to the instrument cluster.
A continuity check from pin 85 on the front of the fuse box to the light blue wire that connects to the back of the instrument cluster showed the wiring was OK.
I concluded it was an internal problem in the instrument cluster circuit board. I didn’t see burn marks or anything obviously wrong so I shipped it to Circuit Board Medics
A few days later, it came back and everything is working perfectly again!
Thank you guys for your help on this. And if anybody is having this problem, feel free to shoot me a message if you want help.
Old Aug 16, 2025 | 11:12 AM
Eman85's Avatar
Eman85
I and others will appreciate your follow up post.
Old Aug 19, 2025 | 03:48 AM
John in OkieLand's Avatar
John in OkieLand
I had to ship off my cluster board also.
RigCity
Nov 9, 2023 09:01 AM
Mickey Bitsko
1997 - 2003 F150
Apr 21, 2019 02:29 PM
robs01f250
Aug 30, 2010 01:20 PM
truckerboy
Electrical Systems/Wiring
May 28, 2010 05:17 PM
olinprice
Dec 16, 2007 12:27 PM
