2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
15 Expedition Limited Driver Door Lock Gremlin
Old Jul 26, 2025 | 06:23 PM
rangerottis's Avatar
rangerottis
Good day everyone!
I have a 2015 Expedition that recently developed an electrical gremlin. The driver door lock stopped functioning except for manually locking and unlocking. At the same time, the "key in ignition" alarm started going off when the driver door is opened. I assumed the actuator was bad and replaced it. As soon as I plugged in the new actuator, the alarm stopped and the door lock began functioning. As soon as I tightened the last screw on the door panel, the alarm started again and the lock stopped working.
I then tested the old actuator by jumping the terminals to the battery, and it was not bad. I took the door panel back off today because I had forgotten to hook the power mirror back up and low and behold, while the panel was of, the alarm stopped and the lock started working! After putting the door panel back on, it no longer works and the alarm is over again going off with the door open. Does anyone have any ideas on what and how to chase this little gremlin?
Thanks in advance!
Old Jul 27, 2025 | 08:04 AM
meborder's Avatar
meborder
I would bet on a pinched wire in the door jam. It’s been a pretty common problem.
it’s possible that things are getting moved around just enough to work or not work when you get in there to work on it.
just a guess based on the most common problem that I know about.
Old Jul 27, 2025 | 06:54 PM
rangerottis
Any idea how to access that harness? Or which wire it could be? A wiring diagram of the locks would be nice... if anyone has one.
Old Jul 28, 2025 | 07:47 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
sounds like you have a short in the door. caused by the door panel somehow.
pull the panel again and see if things start working. If they do, inspect the door. Especially all pinch points and where fasteners are. Probably have an exposed wire that is somehow being "pinched" when the panel is installed; causing a short. Or maybe a fastener is protruding and sticking into a wire bundle. Wiring diagram won't help in this situation.
SchwansManDan
Nov 2, 2013 03:07 PM
fcctobe1
Dec 21, 2012 03:50 PM
mark6x43
Sep 22, 2009 02:59 PM
StevenA
1983 - 2012 Ranger & B-Series
Jun 20, 2003 09:45 AM
breck
Feb 16, 2001 04:14 PM
