6v positive ground Vacuum pump?
Old Mar 12, 2025 | 01:40 PM
8pack's Avatar
8pack
1955 F250 6v positive ground system
I have just finished mocking up the install of my vacuum booster on the power brake conversion with front disc brakes. It struck me that I don't think there is a vacuum source I can use for the brakes on the 223 IL6. I haven't found electric wipers.
1. Does that motor have a vacuum source I can use for power brakes?
2. If not I assume I need a vacuum pump and a vacuum reservoir? What are people using for a 6v system?
I have searched pretty extensively and haven't been able to find a clear answer.
Thanks for the help as always!
Old Mar 12, 2025 | 02:06 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Wipers are connected through the silencer which is plumbed into the manifold highlighted in yellow.
Vacuum brakes are connected at the manifold by removing the purple plug and having a fitting threaded into the blue highlighted opening.
Old Mar 12, 2025 | 02:26 PM
8pack's Avatar
8pack
Wow. Got it. I have electric wipers so that's even better as there is only one draw on the vacuum. I will go take a look and see if I can remove those fittings or if they are out.
Thanks!
Tristian Knutson
Sep 23, 2020 03:29 PM
danlee
May 3, 2017 07:14 PM
danlee
Mar 21, 2017 08:25 PM
jlynn8403
Jan 19, 2014 08:50 PM
RhinoVirus
Mar 15, 2005 12:01 AM
