Forgive me if there are other threads about this topic. I did a search and didn't see any threads titles jumping out at me regarding thermostats.
My primary water pump has failed, and I thought I may as well replace the thermostat while I'm having the water pump replaced. I have a '15 model 6.7 with 144k miles, btw.
I came across an aftermarket primary thermostat, the double one, that opens about 20 degrees cooler than the OEM ~200°F that comes installed. It got me thinking, is cooler better? Is it only better depending on the geographic location of where one lives?
So I thought, if cooler is better, why didn't Ford engineers have a ~180°F'ish thermostat installed to begin with? I'm pretty sure engines have an optimal operating temperature.
Maybe "cooler is better" is an idea, a concept, that merchants use in hopes to establish a belief in someone so they make the purchase and get what they're after, which is the dollars in our wallets. Thoughts?
Running cooler on a Diesel is opposite of a gas engine. Years back, 1999 era, The 7.3 powerstroke ran too cool from the factory so some companies made 203* T-stats as replacements so the engine would heat up faster and run hotter. Diesels are more efficient running hot, they can run a little leaner and get a cleaner burn. It also helps keep temps up when idling since an idling diesel uses very little fuel and not a lot of heat from combustion.
