Looks like my PCM was chipped at one time
Old Jun 14, 2024 | 01:35 PM
dunecj2a's Avatar
dunecj2a
My Son’s 94 F350 460 has been showing some of the symptoms of an aging pcm. He pulled it this morning to clean it up and check the capacitors for leaks. He sent me these pics of what we think is an aftermarket chip that was put on at on time.
is that what this is?
Old Jun 14, 2024 | 02:11 PM
rla2005's Avatar
rla2005
That is an aftermarket chip. Throw it away. Many are known to cause issues.
Old Jun 14, 2024 | 04:04 PM
dunecj2a's Avatar
dunecj2a
Is it ok to keep the end open where it slides on the circuit board or should we try to make a cover?
Old Jun 14, 2024 | 05:27 PM
Conanski's Avatar
Conanski
Seal it up as best you can, there would have been a metalic tape over the opening originally.
Old Jun 14, 2024 | 05:57 PM
TobyB's Avatar
TobyB
Interesting- that plug- on's from the later 90's... and the PCM's 3 years older.
Agreed that that type of connection's not the most reliable...
Me, I'd re- cap the PCM and play around with the 'chip' just to see what it does...
t
Old Jun 14, 2024 | 06:32 PM
dunecj2a's Avatar
dunecj2a
Thats what I figured. I didn’t think that circuit board end would be exposed.
Old Jun 14, 2024 | 06:40 PM
dunecj2a's Avatar
dunecj2a
From what I can tell the capacitors dont seem to be leaking. Can they fail without them leaking? Is there anyway to test them with a meter?
we are trying to troubleshoot the stumble/shutter he has at 35-45 mph 1200-1500 rpm.
Christian A
Apr 14, 2024 12:38 PM
Lbrewer83
Dec 31, 2021 06:17 PM
cjgray1974
18
May 20, 2014 03:17 PM
Tugly
32
Feb 11, 2014 09:42 AM
