292 With Various Issues
Old Jun 2, 2024 | 08:34 PM
KK560's Avatar
KK560
I got a 61 F600 that I've had for a year or so, and have had it running before, but it ran rough, so I rebuilt the carb, replaced ignition parts, water pump, intake gaskets, exhaust gaskets, thermostat gasket, valve cover gaskets, and adjusted valves. When I first had it going the oil was just old and black, so I changed it. Now I'm trying to set the carb and timing, but can't keep it running under 1100rpm, plus there's coolant getting in the oil. Do I have a blown head gasket now? How do I get the idle to slow down without it dieing?
Old Jun 29, 2024 | 05:12 PM
KULTULZ's Avatar
KULTULZ
Post
... tsk ... tsk ... tsk ...
The HI-IDLE is most likely due to a mis-adjusted linkage/carb/choke (manual?) or a vacuum leak.
If coolant is getting into the oil, possible head/intake gasket(s), front timing cover gasket @ water pump.
pi653
Nov 26, 2016 10:10 PM
fluknick
16
Jun 10, 2012 11:45 PM
robe
Jan 17, 2010 04:09 AM
nmarlowe
Dec 28, 2003 04:56 PM
Chevy_Monza
May 22, 2003 03:09 PM
