Does anybody know what purpose these serve?
All four layers are spot welded together, which was verified on both sides. the drivers side is totally rotted out on the roof skin/outer layer. as seen in the first photo, passengers side is not rotted out, but has rust started.
bolts and nuts totally rotted out on drivers side
Even though all layers are spot welded is there any reason for these that anybody can think off? the individual screws do not seem to serve any purpose. is there a light bar or a roof rack from ford that bolts in here?
To save money I suggested to Shinobu that he just remove the rusted portion replace with sheet metal and weld a rosette from the inside where the nut was, which would secure the piece in place just as strong as a bolt but it would save him time, and me money.
is there any reason not to?
i will double check tomorrow though.
blue circle is striker plate under plastic drop cloth
Edit: Oh, I just saw your blue circle. Yeah I have no idea what those bolts do then.
Wonder if it had like a light bar on the roof at one time. Like a strobe/wig wag caution amber light and those are where the mounted them to?
thank you to all of you who replied and commented.
after reading Tpayne's comment I felt much better and you all have reinforced my thoughts as when we looked at it from behind with the bore scope there was no real reason for the threaded inserts. i just wanted to make sure. I already told my body man to cut out the entire section of sheet metal and replace with new for both sides.
I will post photos of the process as Shinobu promised me pictures of all work (which means I need to coddle myself and cry a bit when the bill comes). he normally does exotic car restorations. think rotisseries, full body soda blasting or even dipping in some cases to remove all rust prior to welding in new. I am not going that far, just cut out, weld in bead blast both sides, hammer flat and paint.
The lower side of the drivers door will be more intense as it has centurion (i think) graphics on it and he wants to avoid repainting the entire door to replace a sticker that is no longer made, but only has four inches to work in. should be fun!
As for the decals, have you considered reaching out to a local vinyl/sign shop to see if they can reproduce it? I've heard of people doing that for obsolete decals in the past.
I'm fortunate that mine doesn't have any graphics, just Oxford white, so finding replacement panels should be easy for the dented/damaged stuff. Unfortunately, a bunch of the Oxford white panels I've found have the lower accent color like gold or silver. Vinyl might even be a solution to make those replacements easier to use. I could pretty easily get a camo or other color wrap applied to hide and make that section match.
EDIT: Just realized who I'm replying to. Being over there in Japan, your parts availability probably isn't going to be the same anyway. On closer look at the picture, I realized you haven;t removed the same seals I'm thinking about anyway.
all of my rubber seals are in really good shape, it appears the PO changed them out in the last 4 or 5 years. not sure where you can purchase but as the body did not really change for almost a decade I would bet you can still get them from ford.
