Exhaust back pressure valve
Old Dec 18, 2023 | 05:47 PM
Oilfieldscum's Avatar
Oilfieldscum
So this is a wierd one. Had buddy install my turbo I'm so busy, well the ebv stuck closed right after so I unplugged it. Well it seems that it also came unhooked the little rod. So it was fine drove it around for quite awhile but hasn't sounded quite right. Today I get the chance to look at it and it has either been closed or partly closed? Towards the turbo is open correct? Or atleast for me it sounds like it is and my exhaust back pressure stays around 13 14 when I floor it in park. Before it would skyrocket. Hopefully I didn't cook the turbo.i wired it so it seems to be open. Not sure if buddy forgot to hook up the rod or the clip came off. It was dark when I finally got the truck going it was a ordeal. So I just unhooked the ebv sensor in the pedestal there and I thought it fixed my problem but I guess it only did it half way?! Wierd
Old Dec 18, 2023 | 09:08 PM
RacinJasonWV's Avatar
RacinJasonWV
Someone else is working on the same thing right now. He’s got an answer to your question.
https://www.ford-trucks.com/forums/1...l#post21069491
Originally Posted by Lex2002
I got this explanation from Diesel O rings:
The piston pushes the valve closed. With the piston extended the valve will be closed.
When the piston arm retracts back into the pedestal, the valve opens.
Engine off and key off, the valve should be open, piston will be retracted.
Old Dec 18, 2023 | 11:39 PM
Oilfieldscum
Yea, so I was driving around with it partly closed or closing at certain times. I could hear what I thought was a boost leak, but couldn't find any. We'll yea with it wired open, I am now building proper boost and sounds way better. I got to test it out tonight in street tune, darn dog ate a bunch of my wife's thc gummies, so had to rush it to the vet half hr away. Truck is like a whole diffrent truck. Now hopefully I didn't damage anything inside the turbo driving it around like that.
daveroderick
13
Jan 5, 2012 08:55 AM
raydav
Apr 14, 2008 03:29 PM
01PS
54
Oct 13, 2007 12:37 PM
DaFueler
Jan 15, 2007 06:01 PM
PwrStroke7.3
Feb 26, 2006 09:06 AM
