Locking Hubs head scratcher!
Old Dec 11, 2023 | 12:35 PM
ZachinCO's Avatar
ZachinCO
Recently replaced my ball joints and axle seals, along with a few other steering tie rods. Had everything back together, so I thought. I guess I didn't get the PS locking hub retainer clip in properly and lost the unit somewhere.
Well, picked up a replaement at O'Reilly and just can't seem to get it in far enough for the retainer clip to seat in the groove.
Picked up this one~ https://www.oreillyauto.com/detail/c...ing+hubs&pos=4
I thought maybe it was something in my reassembly done wrong. I double checked the washers on the shaft and snap ring, they are all in properly. Took out the DS hub and I can put it in and the ring snaps in and seats.
Got to looking at the SPECs on the hubs offered, one says:
  • Outside Diameter Of Axle (mm): 30mm
Another says
  • Outside Diameter Of Axle (mm): 33mm
Could this be my problem?
EDIT: I put a caliper to both my old one and the new DORMAN and I can't see any size difference. Only thing might be the flange were the O-ring sits.
Old Dec 11, 2023 | 02:37 PM
z31freakify's Avatar
z31freakify
Did you lubed the O ring on the locking hub? Some locking hubs require some force to get them where they need to be. You could probably get a rubber mellet and smack them in or apply some pressure with you hands. I had a hard time getting some new locking hubs in my 00 to sit right.
Old Dec 11, 2023 | 04:41 PM
ZachinCO's Avatar
ZachinCO
I thought I had enough, I'll try some more tonight.
Old Dec 11, 2023 | 05:14 PM
INFRNL's Avatar
INFRNL
If i'm not mistaken, you also want a light coat of lube on those teeth as well.
Everything looks ok, so it should go in. I don't think anything could be stopping it. Maybe give it some love taps with a rubber mallet/ dead blow
Old Dec 11, 2023 | 07:05 PM
udsuth78's Avatar
udsuth78
Yeah I always would start the spring clip then pop the outer rim of the lockout with a mallet or block of wood w/ hammer. For in case purposes double check all the splines are smooth and uniform. Even just a nick on 1 can throw a wrench in the works.
Old Dec 11, 2023 | 07:44 PM
INFRNL's Avatar
INFRNL
I'm thinking for whatever reason, the o-ring is holding him up and just needs a little help as you mentioned.
Old Dec 11, 2023 | 09:24 PM
RigCity's Avatar
RigCity
Yep, had to modify my new drive shaft assembly the other day 🙃 also helps to grab the u joint and wiggle it
Old Dec 12, 2023 | 08:12 AM
ZachinCO's Avatar
ZachinCO
So I ended up getting it in last night. I had tried the dead blow hammer with a block of wood up against the hub.
After the O-ring was mentioned, I took a big flat head and lightly tapped around the outter edge and that did the trick to get it to seat in all the way and the locking ring snapped into the groove.
Guess I was just being to cautious.
Old Dec 12, 2023 | 11:11 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I think you were properly cautious. Going full Hans Hamhands straight off is never a good idea.
Old Dec 13, 2023 | 12:39 AM
INFRNL's Avatar
INFRNL
glad you got it
Old Dec 13, 2023 | 10:35 AM
udsuth78's Avatar
udsuth78
When in doubt, hit it harder. I'm sure somebody famous said the sometime, maybe it was Gandhi.
Old Dec 13, 2023 | 11:47 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Or larger hammer
Old Dec 13, 2023 | 04:45 PM
INFRNL's Avatar
INFRNL
I have something like this 10lb...should be plenty
Old Dec 14, 2023 | 01:11 AM
udsuth78's Avatar
udsuth78
Does your wife know you have her hammer?
burnthelight88
21
Dec 19, 2018 12:40 PM
Cloverro
81
Jul 20, 2018 09:42 PM
Jakesford
Sep 1, 2017 02:28 PM
Jeremy Morgan
Offroad & 4x4
Jul 1, 2017 01:38 PM
johnboy427
1978 - 1996 Big Bronco
Apr 20, 2008 11:34 PM
