Check gauges light
Old Dec 11, 2023 | 03:57 PM
Shovelheadrob's Avatar
Shovelheadrob
Check gauges light
A friend has a 2003 F250, it's developed an issue where the gauges will randomly go full sweep, then off, no codes, only the check gauges light. I've said to check earth's & cluster connection. Truck stays running.
Any suggestions welcome.
Old Dec 11, 2023 | 04:04 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If he has the ribbon cable style like my 2000 has, he can use an eraser (like on the back of a pencil) to clean the contacts. Then, use some contact cleaner to rinse them.
This is an old trick I learned many years ago and have used it on a couple of occasions. Once was to fix the control panel on an LG stove/range.
Old Dec 11, 2023 | 04:33 PM
udsuth78's Avatar
udsuth78
Yeah that sounds like they're resetting from a power loss. Which of course can be caused from the + and - sides of the circuit.
Old Dec 11, 2023 | 05:14 PM
Sous's Avatar
Sous
FTE Emeritus
Doesn't the 2003 have that positive terminal block/connection under the airbox that is notorious for corroding and failing? Might have your friend check that spot.
Old Dec 12, 2023 | 12:51 AM
Shovelheadrob
Thanks guys, I'll pass this on, I know the '03 is a bit different as it has a different gauge placement to the earlier trucks, along with a trans temp gauge.
Old Dec 12, 2023 | 01:13 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
"Stays running" might be explored in detail.
On mine the problem was a momentary disruption of power due to a failing ignition switch. See pic.
The engine (and dash) would cut out for a fraction of a second, so that the engine would restart instantly. Driving down the road a person might not notice the engine cutting out briefly. The time increases as the fault evolves. But the dash had to go thru new start protocol including all start up lights activating. 2002 and 2003 should be the same as far as the dash is concerned.
Old Dec 12, 2023 | 09:52 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The difference is much deeper than that.
Unlike the gauge cluster on a 2000, the 2003 gauge cluster is a linked node module on the truck's data communications network.
Old Dec 13, 2023 | 12:59 AM
INFRNL's Avatar
INFRNL
Interesting. I've seen a couple recent threads on a couple different forums saying they have a weird issue with the cluster rebooting or whatever. this might be the cause. I might have to steal this if I come across it again
this might be one of the threads, can't remember
Old Dec 14, 2023 | 01:36 AM
aawlberninf350
It's a Van Gogh
Yeah it was a bitch to diagnose. So to spread the word I post up as elaborately as possible when it seems a likely cause.
It's an 02 and 03 thing since the dash is more of an integrated component instead of a simple display.
twise
Jul 23, 2013 03:51 PM
Snowseeker
Sep 13, 2010 08:19 PM
03-6L-X
Nov 4, 2009 03:57 PM
Chance_Thomas
May 3, 2007 04:42 AM
