5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Hi all, 5.0 misfire problems
Old Nov 27, 2023 | 09:15 PM
Budlight67's Avatar
Budlight67
Trailering
Have a 2014 F150, has developed a misfire on bank one(P0300). Took to dealership, was told to change plugs. I did but did not help. Another ford mechanic said to change injectors, that didn't help either. Can't afford to keep throwing parts at it. Anyone else had this problem?
Old Nov 28, 2023 | 03:31 PM
justanotherjo's Avatar
justanotherjo
there are only a few things that typically cause a misfire:
plugs
injectors
coil pack
It's a tough guess sometimes which one is the culprit.
Old Nov 29, 2023 | 08:19 PM
Budlight67's Avatar
Budlight67
Trailering
It definitely is, wouldn't be so bad if it was just one but it's bank one. All four, I swapped two coil packs one from each side and no difference. Thanks for responding.
Old Dec 3, 2023 | 04:02 PM
30120F150's Avatar
30120F150
2nd Gear
I'm currently having similar issues with my 2015. My misfires are on bank 2. I think I have narrowed the problem down to the variable camshaft timing solenoids specifically the intake solenoid on bank 2. I can explain things I've checked that led me to that conclusion if you end up wanting that info.
My truck has close to 133,000 miles. How many miles does yours have? And do you have any other symptoms?
I've always looked at these forums but finally just made this account in hopes of some mutual aid.
Old Dec 5, 2023 | 02:29 PM
Budlight67's Avatar
Budlight67
Trailering
Mine is bank one, only codes are miss fire and o2 sensors bank two. Not getting any cam sensor codes at all. Nothing else at all. Info would be much appreciated. Can't see o2 sensor on bank two causing miss fire on bank one. 213k
Old Dec 6, 2023 | 12:17 PM
30120F150's Avatar
30120F150
2nd Gear
OK I actually don't have any codes so mine has been interesting to get to the diagnoses where I'm at now. I did change both of my upstream o2 sensors towards the beginning of my process because I had some readings that seemed strange but I didn’t have a code. Is your o2 sensor code saying that it's out of range or is it not having any response?
Old Dec 8, 2023 | 01:55 PM
Budlight67's Avatar
Budlight67
Trailering
Not sure on the o2 code, it is on downward side opposite side of bank 2. Problem is on bank one. No cam codes or crank codes.
Old Jan 13, 2024 | 08:44 PM
TheMunsie's Avatar
TheMunsie
Trailering
Did you ever figure out the root cause here?
Old Mar 20, 2024 | 02:45 PM
wedwebel's Avatar
wedwebel
Trailering
5.0l #4 misfire
I replaced the spark plug, coil & fuel injector all with Ford products. After resetting the code, it will come back in short order. It comes on immediately when cold. Help!
Old Mar 2, 2026 | 01:19 PM
rsylvstr's Avatar
rsylvstr
what was the final fix?
Jay
2015 - 2020 F150
Oct 26, 2021 12:39 PM
yote'hunter
Sep 4, 2012 04:46 PM
philn
Modular V8 (4.6L, 5.4L)
Sep 15, 2009 08:45 PM
kaboom10
1997 - 2003 F150
16
May 28, 2008 03:21 PM
