engine rebuild or swap rocker arm failure
i have a 2014 with 225k on the clock, i have only owned it for a couple of months, fully deleted, ran great for the first few weeks and then started with a dead miss on #4
i changed the injector and changed the iqa number, still had the miss, and just kept smoking worse
pulled the passenger side valve cover and the rocker arms are completely shot, i was able to pull 4 of the pushrods out by hand with taking anything loose.
im in the process of pulling the head to see if there is any damage to the cylinders, i can see that one of the lifters is turned 90 so im afraid the cam will be toast
my question is if the lower end seems ok should i just replaced with fresh heads and new valve train or go with a newer used engine ? if i go with a newer engine to get the newer style turbo what year would be the best to go with ?
thanks for any help
thanks for any help
on one hand
My previous truck which was a 6.4 had issues which were basically just rocker arms and push rods. After changing them the truck ran fine.
it costs me 800 bucks in new parts to change all the rocker arms and push rods.
my advice would be to go that route before assuming you need lifters, cams, etc.
You can also bore scope the cylinders to check for damage.
On the other hand, I read some where that the 6.7 was a 300k mile engine before needing rebuild…some have made it beyond 500k miles just fine.
on one hand
i have 2 different borescopes and neither will fit in through the injector or glow plug hole, is there another way to see into the cylinder ?
if the bottom end is good that is sort of what im planning, new heads and new valve train, i know at least one of the holders for the lifters is bad and probably one lifter but that is all work i can do myself
thats what im hoping for im in the process of pulling the heads so i can check everything, almost have the passenger head off not looking forward to doing the drivers side but oh well lol
speakerfritz that video is what got me to pull the valve cover, after i watched it i figured i had the same issue
The following users liked this post:
Thinlizzy13
10-11-2015 03:47 PM
Ironmike86
45
03-29-2014 06:50 AM
