Does anyone have 360 Camera alignment issues. i.e. parking lines don’t line up from front to side cameras, image is not stitched together correctly. Dealer has tried to fix with recalibration but same thing after. The rear is off a tiny bit, but much more acceptable. They say it’s as good as it can get. I think for $92k it should line up perfectly…
Just curious if everybody’s cameras are perfect, slightly off, or worse. Just deciding if I want to pursue this with the dealer, or if it is normal expectation.
That is not normal. The parking spaces should line up just fine. Now, if you put a lift on it, then it will look like that, but a stock truck, that is unacceptable.
it has a Carli level kit. But this did this when it was stock before I put the level kit on.
Can anyone with a level kit confirm if their cameras are off or good? Got back from the dealer, they tried, I think made it worse, and they are scratching their heads and unwilling to do anything else.
