Sponsored by: Real Truck
2002 Powerstroke, clicking coming from INSIDE fuse panel?
Old Aug 26, 2023 | 04:41 PM
dorkpunch's Avatar
dorkpunch
Hi guys,
2002 Excursion 7.3 Been chasing a battery drain and some wiring gremlins. Started pulling fuses and measuring the amp drain today. About halfway through the process, a relay inside the fuse panel started clicking. It doesn't seem to affect how it runs. Starts, idles, has plenty of power, but it just clicks like crazy. It wasn't doing this before I started pulling fuses. I've also noticed the trip computer in the overhead console went out and the switches up there don't work to open or close the rear side windows. Not sure if that's related? It's driving me bonkers and I'm sure its going to make the battery drain worse. It seems to stop after about 30 seconds of shutting it off, but it will do it randomly just sitting there, no key or anything. Any type of blip in electricity does seem to set it off- opening the door and lights turning on for example.
Found these pics in a different thread here but I don't have the same issues as that person was. Second one shows the back of the fuse panel, pointing at the internal relays that are making the noise.
Vid of the noise:
https://dorkpunch.smugmug.com/Powers...n-/i-sDBcfr5/A
Old Aug 27, 2023 | 02:27 PM
Matthew_in_CO's Avatar
Matthew_in_CO
This may sound crazy but have you disconnected batteries to reset the various computers? Doing some light research it sounds like you may have an issue with the Body Control Module (BCM) or Vehicle Security Module (VSM). Or maybe one of those internal relays is a delay relay for the overhead console? Not really sure.
If one of these were acting up they may be your parasitic draw.
Just to be sure, are you confident you have a parasitic draw? I have started chasing those before and it turned out to be a poorly crimped cable end preventing the amperage flow to the starter. Just a thought.
Old Aug 27, 2023 | 02:45 PM
Matthew_in_CO
Also if you can get the clicking to stop by pulling a fuse be sure to note which fuse it is!
Old Aug 27, 2023 | 09:51 PM
dorkpunch's Avatar
dorkpunch
If I let the truck sit for more than a week, the batteries would be dead. Brand new batteries.
Old Aug 31, 2023 | 07:24 PM
dorkpunch's Avatar
dorkpunch
Few other things I've noticed while driving it the last week.
Still runs great. No issues starting, driving, etc.
On a whim pulled up codes on the Edge tuner while waiting in line to pick up kids today. Have a P0672, 674, 676, and 678. Basically, it doesn't sound like any of the drivers side glow plugs are working but that doesn't make sense. Is there a relay that controls just the one side of glow plugs? Could that be related to my clicky issue?
Old Sep 1, 2023 | 09:43 AM
Matthew_in_CO
Is your Ex California emissions compliant? Those get a special glow plug controller, so they can alert you to specific glow plug failure. Sounds like you may have a UVCH coming unplugged or a wiring problem between the GPC and that bank. Fun.
For troubleshooting please be sure to eliminate the Edge as part of the problem by running for a while without it. It's such an easy step.
Grab forscan and check all your modules for trouble codes.
Good luck!
Old Sep 23, 2023 | 02:05 PM
dorkpunch's Avatar
dorkpunch
Potential update:
While playing with some things today, I noticed that the clicking will STOP, but only if I hold the horn down. The horn must not be connected, because the horn does not work. If everything is off, after the clicking has stopped, I can push on the horn and it will click and release normally. Turn the key, trigger the door light, anything else, and the clicking goes wild.
Probably unrelated, but curious- I have the intermittent power windows and radio glitch where they just stop working, also seems to affect the cruise, and possibly the A/C but I think that may be a separate issue.
dcboyle
Apr 15, 2022 09:02 AM
yzf450motoxrider
Jun 2, 2018 12:04 AM
BignUgly-LikeMyTruck
Aug 13, 2012 03:50 PM
garyh8
Aug 17, 2011 10:09 AM
mattv1
Electrical Systems/Wiring
Sep 14, 2005 11:09 PM
