Hello, my 2012 F250 that I bought used had suspension bags in the rear that the previous owner left installed. He wasn’t nice enough to leave the compressor or other components when he sold it 😕
My question is I really have no idea if the bags are still functional and are worth attempting to use. I’ve heard good things about sumo springs and timbren so I wonder if I should take out the old hardware and start over or would it be better to try and use the suspension already in place. I tow a travel trailer at around 10k fully loaded and don’t have too much squat with my weight distribution but I have some issues with “porpoising” on the highway. Any suggestions would be greatly appreciated.
Did the prior owner just cut the air lines? Or, is there a Schrader valve somewhere that you could put an air chuck on. These valves are often located by the license plate or in the fuel door area. If it was me, I would keep the air bags, just in case.
Porpoising can be caused by a trailer that is not well balanced (not loaded right front/back), a WDH not configured quite right or front shocks that need to be replaced. There could be other causes, that those are the ones I can think of right now.
I was able to trace the airline into the cab of the truck where it stops under the rear passenger seat. There are drill holes that looks like that’s where the compressor was located. I’ve never had any experience using air suspension the only knowledge I had was from YouTube surfing. I swapped out the old rancho shocks with some new bilsteins after I first had the issue thinking that would solve it but it didn’t. Can I just hook up a compressor to it and see if they hold air?
I have a 2013 with the Air Ride 5000 bags. No issues to date with the bags, I mounted the air pump out under the hood, with a gauge/button inside the cab. Can add adjust the air running down the road at anytime.
As long as the bags on your truck hold air, I would use them. You can buy air pumps, etc on the internet to get them working.
You will need to know what make they are, (Air Ride, Firestone).
Mine are Air Ride. You can call Air Ride direct, and they will sell you what you need to get them working. They are great to work with.
My old 2001 Ford Diesel, sold to a friend are the same Air Ride Bags, and still work today with out any issue.
Your choice on what you want to do. If I had a new truck, I’m not sure what way I would go.
If he cut the lines and the truck has been driven with Zero psi in the bags. They may be ruined. Firestone bags in particular need a minimum air pressure so they don't bottom out and destroy the bags.
Put a valve on the line and pressure up the system and see if it hold air..
I suspect your porpoising is due to your WDH doing too much and your springs not enough. I had the same problem with my nearly 10k lb camper. It drove us nuts. Hooked it up w/o bars and leveled with air springs and test drove. It was night/day different, though it does still need some WDH help, just not what I was giving it. I've found the F250's to be slightly undersprung when towing weight, in and above, this weight. Air springs helped a lot.
BTW, if you want to hook up your system, you don't need the air compressor. Just two push lok schrader valves on the end of the lines to the springs and air them up manually. Very inexpensive to do and you will find out if springs are good or not. Search "push lok schrader valve".
Like Prostock said, you can just add schrader valves and be good to go. A compressor setup is definitely an upgrade, but many people (including me) run airbags without it. I’ve shopped compressor setups many times just never pulled the trigger. I don’t do a lot of adjusting of the pressure.
what would be a good psi to operate with, assuming that they hold air of course?
Update = I was able to use my hand held air compressor to inflate the airbags with the schrader valve and it has held air for a few days with minimal loss of psi
