1973 360 HELP!
Old May 7, 2023 | 01:28 PM
Wheelsoftime's Avatar
Wheelsoftime
2nd Gear
1973 360 HELP!
Hello,
first time in this forum. purchased a non running 1973 ford, 2wd 360 VIN. someone has put 4 bbl and headers on this truck. so far....
1. new spark plugs from prior owner - looked like they never ran
2. removed pentronix ignition and put points back in
3. new ignition coil
4. was able to get it running but when timed "correctly" (10 btdc) it knocks VERY badly and will not stay running
5. we plugged the vacuum ports on the manifold and under the holley carb
6. if advanced by 20-30 degrees the engine will run smooth but it still sounds like at least one knock
Any thoughts on what else to check before ripping into the cam and removing the engine to check rods
Old May 7, 2023 | 02:32 PM
kenny nunez's Avatar
kenny nunez
360 timing
Verify that the “0” on the harmonic balancer lines up with the pointer then #1 is at TDC.
Old May 7, 2023 | 02:53 PM
Wheelsoftime
2nd Gear
Harmonic balancer
We did confirm 0 and tdc
Old May 7, 2023 | 09:02 PM
kenny nunez
What about the compression?
Old May 7, 2023 | 10:14 PM
Rubiranch's Avatar
Rubiranch
Almost sounds like the timing chain has jumped.
Bring your timing marks to TDC and make sure its on the compression stroke and see where the rotor is pointing.
You can remover the #1 spark plug and crank the engine over with your flinger blocking the spark plug hole to find TDC #1.
SemperFi_YEMX
Dec 20, 2019 12:01 PM
Roll
Jul 17, 2019 03:59 PM
gbass82
47
Aug 27, 2016 01:03 PM
Schickel
Aug 6, 2013 10:23 AM
albcasummit
May 25, 2006 12:29 AM
